Need Help!!!
Old May 26, 2015 | 08:08 PM
zoomer96's Avatar
zoomer96
Default Need Help!!!
My friend has a 2014 Vert that he stores during the winter months. He was in the habit of starting it every couple of weeks to try to keep the battery from becoming too discharged. Unfortunately, he let it go too long and today, the battery was discharged to the point that the drivers door wouldn't open. But he was able to use the FOB to open the trunk. He put his charger on it and the battery is now recharged enough that he can start the car. The problem now is..... he's got a message on the DIC saying the top needs to be latched. If he tries to cycle the top by using the FOB, he gets a message that the trunk must be closed. He attempts to close the trunk, but it won't latch. Obviously, something in the electronics is out of sync but he's been unable to correct the situation. Does anyone has a suggestion for solving this problem? Is there a procedure he should follow to get the trunk to latch?
Thanks for any help.
Old May 26, 2015 | 08:18 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
First thing I'd try is to disconnect the battery completely so everything can reset from having low voltage. Make sure the battery is really fully charged before connecting it. I suspect that will solve his problems.
Old May 26, 2015 | 08:20 PM
REDBLUR's Avatar
REDBLUR
Cruise-In II Veteran
If it were me I would try disconnecting the battery for a couple of minutes and then reconnect it. Maybe that will reset things. He might lose radio presets and things like that, but he may have lost those anyway if the battery was down enough.
Old May 26, 2015 | 08:28 PM
Larry/car's Avatar
Larry/car
After reconnecting the battery have him wait about 15 minutes for all computers to power up before he attempts to start the engine. I didn't and the engine only attempted to turn over, after a few minutes all systems performed normally.
Old May 26, 2015 | 08:47 PM
meyerweb's Avatar
meyerweb
But make sure the battery is FULLY charged before you reconnect it and start trying things again.
Old May 26, 2015 | 09:24 PM
mpuzach's Avatar
mpuzach
A far better procedure for storing over the winter is to use a battery tender.
Old May 26, 2015 | 09:28 PM
LanceVette's Avatar
LanceVette
Got one and use it faithfully.
Old May 27, 2015 | 02:41 PM
meyerweb's Avatar
meyerweb
Absolutely.
In fact, what the OP's friend did is probably the worst way to treat a car over the winter. You shouldn't start it unless you're going to run it long enough to get all the fluids up to normal operating temps. Starting the car drains the batter more than a few minutes running will recharge it. Running it without letting it get to normal temps causes water condensation in the oil and the exhaust system, neither of which is good.
For winter storage, clean it, add some pressure to the tires, hook up a battery tender, and don't touch it again until you're ready to take it out on the roads.
Old May 27, 2015 | 02:57 PM
sanantguy's Avatar
sanantguy
That's all it takes to avoid a big pain in the ***.
Old May 27, 2015 | 03:06 PM
Glen e's Avatar
Glen e
Unless you are storing not near any power, in that case, take the batt out of the car, lock it up and put it on a maintainer inside where it's warm.
Old May 27, 2015 | 09:11 PM
zoomer96's Avatar
zoomer96
Default Need Help
Thanks for everyone who responded. It's still a mystery. He took it to the dealership (needed to go anyway for the gas filler recall and the first oil change) and they didn't immediately know what to do to fix it. I'm sure they'll figure that out but it might take a day or two before he gets the car back and is told what it took to fix it. If you're like me..... you want to know the final fix. Once I know, I'll be sure to post it here.
Old Jun 3, 2015 | 11:23 AM
zoomer96's Avatar
zoomer96
Default Need Help.... Final Fix
As promised, I'm reporting on what it took to fix my friends trunk latch. He was told a plastic part in the latch mechanism had broken. The entire latch mechanism was replaced. He had no other details.
Old Jun 3, 2015 | 07:50 PM
speedlink's Avatar
speedlink
Originally Posted by meyerweb
Absolutely.
absolutely correct!
Old Jun 3, 2015 | 07:51 PM
speedlink's Avatar
speedlink
Old Jun 4, 2015 | 07:24 PM
Get_UmJ13's Avatar
Get_UmJ13
Battery tender would prevent that issue.
Old Jun 4, 2015 | 07:46 PM
rkhegler's Avatar
rkhegler
YUP!
To Need Help!!!
