Active Fuel Management Question
Old May 30, 2015 | 01:04 PM
bowtie123's Avatar
bowtie123
Default Active Fuel Management Question
Hi All,
Is there a minimum speed or gear selection
at which the AFM engages?
Thanks for any info,
Old May 30, 2015 | 01:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
Operation is different between Auto and Manual transmissions. On the Auto, it is active in all Driver Modes. On the Manual, it is only active in ECO Driver Mode.
Old May 30, 2015 | 01:42 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I think he's asking the minimum speed at which AFM would kick in regardless of tranny. As in, would it kick in at 25 MPH or only highway speed?
(I don't know as I never use it)
Old May 30, 2015 | 01:54 PM
Zymurgy's Avatar
Zymurgy
Moderator
Yeah, unfortunately, the manual gives no clue as to what the operating parameters are other than the Auto/Manual difference. Since I have a manual and it is never in ECO mode, I have no experience with it.
Old May 30, 2015 | 02:10 PM
W88fixer's Avatar
W88fixer
Mine (A6) will drop off the line at about 25. Mine is pretty unobtrusive, the only time it is noticeable is when it’s cold or going up a significant hill, so I do use it on interstates. Don
Old May 30, 2015 | 02:14 PM
///ADMAN's Avatar
///ADMAN
I have not been able to find any significant pattern either.
Old May 30, 2015 | 03:07 PM
golden2husky's Avatar
golden2husky
It seems to vary, and it will engage in 4th or 5th as well as the top gears. M7 car. Actually, I don't get the hate over it because on the highway I get 32 mpg and there is barely any lag going in/out. Then again, I can switch it off...
Old May 30, 2015 | 07:52 PM
Lacoven's Avatar
Lacoven
I love getting 30 MPG on the Highway.
Old May 31, 2015 | 11:00 PM
bowtie123's Avatar
bowtie123
Thanks for the info,
I don't really feel it kicking in and out.
Just a little concerned about the fouling etc.
Thanks again,
Old Jun 1, 2015 | 08:26 AM
Ernest_T's Avatar
Ernest_T
I'm surprised how much it kicks into V4 mode. On the other hand, according to the car, I've averaged 25 mpg in the 3000 miles since I picked the car up.
Old Jun 1, 2015 | 10:11 AM
W88fixer's Avatar
W88fixer
What fouling? Do you have a source for your concern or just internet rumor?
GM ran these engines for massive amounts of time on rot gut, garbage gas w/o issues.
Most of the C7s out there have a 5 yr engine warranty. I’ll bet you won’t need it for fouling. Don
Old Jun 1, 2015 | 10:16 AM
Zymurgy's Avatar
Zymurgy
Moderator
If the "fouling" you are talking about is the valves, that is a Direct Injection issue, not AFM. With Direct Injection, there is no fuel washing the back of the valves.
Old Jun 1, 2015 | 10:38 AM
jovette's Avatar
jovette
Yep, believe that I've seen that "fouling" referred to as 'coaking'. a possible issue for all direct injection engines. Good reason to use a top tier gasoline, and maybe a dose of Chevron Techron Plus every year as a pre-emptive attempt to minimize the coaking....
Old Jun 1, 2015 | 10:47 AM
Ernest_T's Avatar
Ernest_T
That won't help the issue with a direct injection engine.
Old Jun 1, 2015 | 12:26 PM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
You can put the DIC in instant fuel economy mode and it will show V8 or V4.
Old Jun 1, 2015 | 12:28 PM
jaden61's Avatar
jaden61
Thanks again,
Fouling? It is never in V4 for long.
Old Jun 2, 2015 | 09:55 PM
bowtie123's Avatar
bowtie123
In driving today, with the instant fuel mileage displayed
and in "D", I found that it would go into 4 cylinder mode
just about any time you let up on the gas or were coasting.
When in "M" it never went into 4 cylinder mode, not even in
8th gear at 60mph.
To Active Fuel Management Question
Old Jun 3, 2015 | 07:33 AM
Sir Nuke's Avatar
Sir Nuke
To the OP.....after seeing your thread a day or so ago....I did a little testing to give you an answer. just remember I have an A8. I had the car on ECO mode and in "D".....and the AFM system would go into V4 mode ANYTIME I maintained a constant speed.....even at 15 MPH. and I gotta tall ya.....going that slow in our cars is REALLY REALLY HARD to do!!! BUT.....it will engage at any speed.
Old Jun 3, 2015 | 08:45 AM
Busa Dave's Avatar
Busa Dave
Ahhhh--excellent point! Yes this is 100% correct and there are solutions to this as well. Mine is going to be done in the near term on my next trip to Florida.... I love the AFM on my Z06 and on my 6.2 in the 2014 Truck it works outstanding. Lets me get a little bit better MPG's on the road esp.
Old Jun 3, 2015 | 08:54 AM
Glen e's Avatar
Glen e
It does not kick in based on speed but load. When the car can maintain the speed on 4 cyl it will do so. F you want to kill the AFM on a manual trans, never use ECO, on an auto trans, buy a range technology AFM defeat module.
