C7 Transaxle leak
Old Jun 19, 2015 | 03:43 PM
bdescalzi's Avatar
bdescalzi
6th Gear
Default C7 Transaxle leak
My 2015 C7 seven speed has developed a very slight leak of fluid from the trans axle in less than 1400 miles. Dealer Svc dept thinks the leak is from a weep hole between the trans and rear end that prevents fluids from transferring from one to the other. Chev Cust Service will not permit me to talk to any technical service personnel.
The dealer has never attempted this project and complete disassembly of the vehicle from the engine back is required to remove the trans axle. This project will require a week and no one knows what parts will be required.
Has anyone have any experience with this problem. I am so leery of letting anyone attempt to scatter my new car all over a shop for a week.
Old Jun 19, 2015 | 06:14 PM
WelderGuy's Avatar
WelderGuy
How bad is the leak? May be better to just live with it.
Old Jun 19, 2015 | 07:02 PM
bdescalzi's Avatar
bdescalzi
6th Gear
I'm going to take the car to another dealer and see if the fluid level is dropping before I let them attempt the repair.
Old Jun 19, 2015 | 07:06 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
Two different oils so they should know which one is leaking. I think it is time for a new dealer.
Old Jun 19, 2015 | 07:19 PM
TEXHAWK0's Avatar
TEXHAWK0
So, is it the transmission or differential?
If it is the axle coming out of the differential, they should be able to replace the seal without removing the differential or transmission.
There is no transaxle like on front wheel drive cars. The transmission and differential bolt together but are still independent.
Old Jun 20, 2015 | 09:38 AM
bdescalzi's Avatar
bdescalzi
6th Gear
GM Customer Service could not tell me the color of the trans fluid or diff fluid. I know they are different components but they are connected with a shaft and a seal. The fluid is pale red similar to ATF. Neither fill plugs seem to have been removed. That's my next step.
Old Jun 20, 2015 | 10:08 AM
simplegto's Avatar
simplegto
If it is an automatic checking the fluid is not easy. The car needs to be on a lift and running with warm fluid. The diff is only a fill plug that is easy to check with a jack or ramps. You need to find a dealer with a good Corvette tech.
Old Jun 20, 2015 | 10:22 AM
ZL-1's Avatar
ZL-1
It says 7 speed. The 7 speed uses red fluid, the diff does not. It's understandable that the owner doesn't want an inexperienced tech pulling the driveline out of his new C7. Luckily Dunedin FL is only 50 miles from the biggest Corvette dealer in Florida. Stingray Chevrolet in Plant City has experienced Corvette techs.
Old Jun 20, 2015 | 12:11 PM
simplegto's Avatar
simplegto
That is a good point. I was driving by Stingray yesterday and a load of new Corvettes sat there on the truck with the covers still on.
Old Jun 20, 2015 | 01:36 PM
Sounds to me like a trip to Stingray Chevrolet would be in order. I'd want a tech that has lots of experience with Corvettes to take a look at it and repair as needed.
Old Jun 20, 2015 | 09:00 PM
Gary '09 C6's Avatar
Gary '09 C6
uugghh...
Old Jun 20, 2015 | 10:14 PM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
Maybe the dealer told you that, but I can't imagine a scenario where Chevy Customer Service would shut you out. My best guess is the dealer told you that to keep you out till it's done. I'd pass that up the line through the Chevy customer service reps on here to get feed back from them. Best of luck, it should be ok when done.
Old Jun 20, 2015 | 11:22 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Great advice---NOT!
Old Jun 21, 2015 | 07:46 AM
bdescalzi's Avatar
bdescalzi
6th Gear
Well; believe it. I was on the phone with GM Cust Svc. in Detroit. They said GM techs will be contacted by the dealer only. if the dealer service needs advice on repair. The Dealer took me into the Shop with my car on the rack to show me the leak and explain what they would have to do.
Old Jun 22, 2015 | 09:54 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hi bdescalzi,
I am deeply sorry to hear about your service concerns while at the dealership. I would be happy to look into this further and offer assistance while your car is being serviced. If this interest you, please send us a personal message with your VIN, mileage, contact information and involved dealership.
Kindly,
Kaylee D.
Chevrolet Customer Care
Old Jun 22, 2015 | 09:58 AM
FLS2K's Avatar
FLS2K
Go see Lou at Stingray.
Old Jun 22, 2015 | 10:09 AM
Flame Red's Avatar
Flame Red
Just an FYI - Keith is the Vette Tech @ Autonation on West Colonial here in Orlando, removed and replaced my A8 tranny in a single day. I assume he could do this work for you if you wanted to travel that far and get it done right.
To C7 Transaxle leak
