Coolant
Old Jun 23, 2015 | 12:45 PM
mikesmarga@verizon.n's Avatar
1st Gear
Default Coolant
I have a 2016 C7 on order. Like my 2000 H.T., I plan on keeping it for a least 15 years. I am planning on installing a 180 F thermostat and using Evans waterless coolant (never needs changing) for preventative maintenance, since I live in hot So.Calif.. Would this improvement or a aftermarket CAI interfere with the factory warranty? Thanks Mike
Old Jun 23, 2015 | 03:12 PM
Larry/car's Avatar
Larry/car
Why keep it so long. Change often, every 3 years and never do any maintenance.
Old Jun 23, 2015 | 03:50 PM
LIStingray's Avatar
LIStingray
I am pretty sure both the 180 degree thermostat and non-spec coolant will void the warranty - as will a CAI with tune.
You'd be far better off sticking to the factory thermostat and doing the every 5 year coolant changes.
Old Jun 23, 2015 | 04:50 PM
juanvaldez's Avatar
juanvaldez
Evans is pretty much advertising hype BS. It is propylene glycol. Pure water transfers heat better the any propylene glycol mix or pure propylene glycol. Even though I like G05 anti-freeze, I plan on using the stock fill 'til the warranty expires at least.
Old Jun 23, 2015 | 04:57 PM
W88fixer's Avatar
W88fixer
You’re correct on the cooling issue but pure water w/o proper antifreeze results in internal corrosion and over time, probably very expensive repairs or destruction of the engine. Not to mention a possible cracked block in very cold temps.
The factories don’t make specific recommendations just for giggles. Don
Old Jun 23, 2015 | 07:00 PM
carpe dm's Avatar
carpe dm
To Coolant
