Jacking up the C7
Old Jun 28, 2015 | 01:47 PM
BladeSilver2015's Avatar
BladeSilver2015
Originally Posted by JerryU
The is no place next to the jack stands to put jack stands. They would be on the rocker panels, which are composite reinforced plastic and will crack. The jack stands can be put on the green circles or blue circle/area.
Here is an option that will work if you don't mind spending the bucks:
http://www.jackpointjackstands.com/Home_It_Works.html
Old Jun 28, 2015 | 02:37 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Very interesting! Never saw that concept before. Looks safe as well. Only need one jack however a lot more money than two $60 jacks and jack stands under the GM cradle jack points.
In fact I used a combo old scissor jack and low profile hydraulic jack until I recently bought the other low profile hydraulic jack when it was on sale. I liked the idea that I did not have to be sure the jack rolled under the car to keep the proper alignment of the jack saddle with with the jack pad/puck.
Scissor Jack is inexpensive and less concern about maintaining alignment with jack pad/puck than with Hydraulic Jack..
