Newbie?
Old Jul 1, 2015 | 07:01 AM
Cee7's Avatar
Cee7
Navigator
Default Newbie?
My window sticker says my car has 3.42 rear gear....is that possible with 8spd auto? Dealer manual says not in auto....
Old Jul 1, 2015 | 07:02 AM
Cee7's Avatar
Cee7
Navigator
Is window sticker kinda like generic thing or could it b true?
Old Jul 1, 2015 | 09:31 AM
Sir Nuke's Avatar
Sir Nuke
YES....sort of......it lists all the STANDARD equipment (stii that EVERYONE gets, i.e. manual transmission)...... then if you look closely at your sticker....it also shows that transmission as a option, the A8.
Old Jul 1, 2015 | 09:39 AM
Cee7's Avatar
Cee7
Navigator
I kinda figured it was like a generic thing......so no 3.42....rats
Old Jul 1, 2015 | 09:41 AM
W88fixer's Avatar
W88fixer
Wow, if that were actually done, taking a C7 with A8 and changing the axle ratio to 3.42, a 41% increase in gearing? Smoking the tires through 3rd gear??? Don
Old Jul 1, 2015 | 09:45 AM
Red C8 of Jax's Avatar
Red C8 of Jax
Think the A8 C-7 has 2.41
Old Jul 1, 2015 | 02:22 PM
duanepillar's Avatar
duanepillar
My 2015 Z51 A8 has a 2.73 according to the build sheet.
Old Jul 1, 2015 | 05:37 PM
Red C8 of Jax
The Base Stingray has 2.41.
Old Jul 1, 2015 | 06:28 PM
Czarvette's Avatar
Czarvette
If you could do it, you could probably pull stumps out of the back yard, too.
Turns out that the M7 with 3.42 rear end actually is taller (lower total gear ratio, engine to wheels) than A8 with 2.41 rear end.
gear M7 total A8 total
1 2.66 9.11 4.56 10.99
2 1.78 6.10 2.97 7.16
3 1.30 4.45 2.08 5.01
4 1.00 3.42 1.69 4.07
5 0.74 2.53 1.27 3.06
6 0.50 1.72 1.00 2.41
7 0.42 1.45 0.85 2.05
8 ----- ----- 0.65 1.57
rear 3.42 ----- 2.41 -----
Old Jul 1, 2015 | 11:56 PM
Heck of a difference between the M7 and A8 rear gear ratios.
To Newbie?
