Breaking It Loose
Old Jul 2, 2015 | 12:05 AM
OrioleFan's Avatar
OrioleFan
Default Breaking It Loose
If anyone has seen a few of my posts they know I'm two months in and only 113 miles. I'm not close to getting past the break in period point but...
When I do I'm wondering, can you break the tires loose in 2nd or 3rd gear? Should you go easy on the throttle or does it hook up easy?
Car is a 7Speed Z51.
Old Jul 2, 2015 | 08:11 AM
LIStingray's Avatar
LIStingray
If it is dry and above 70 degrees out, the rear tires have no problem holding traction at full throttle in second and third gears - first not so much.
Old Jul 2, 2015 | 08:13 AM
billythekid310's Avatar
billythekid310
I think my car had 4-5 miles on it before I went all the way through 3rd gear. I was by the assembly plant.
Go ahead and give it a go.
Old Jul 2, 2015 | 12:59 PM
Bill B 1's Avatar
Bill B 1
Depends......with TC off it should break loose fairly easily in a straight line in 3rd.....enough to see faint black stripes on the road anyway.
Old Jul 2, 2015 | 07:01 PM
dvilin's Avatar
dvilin
Old Jul 2, 2015 | 07:26 PM
VINDIC8R's Avatar
VINDIC8R
Banned Scam/Spammer
I totally agree about first gear. I have an A8 and my C7 breaks loose very easily at initial throttle up. So easy in fact I am wondering if my nannies are even working properly. When the car does get loose it is my taking the foot off the throttle that brings me back into a straight line. The nannies do not react fast enough.
The thing is when I watched the launch control demo at Spring Mountain that C7 went perfectly straight.
Not sure what if anything is wrong with my C7.
As for 2nd gear and up I have had no loose issues.
Old Jul 2, 2015 | 07:29 PM
Doodidle's Avatar
Doodidle
take off traction control and let her eat. do it in a parking lot first if you haven't gotten a feel for your car. make sure to throttle out of it, don't let off or you might whip back and over correct.
Old Jul 2, 2015 | 08:03 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
113 miles in two months and you're asking about spinning the tires?
Old Jul 2, 2015 | 08:15 PM
NoOne's Avatar
NoOne
Why even buy the car?
Old Jul 3, 2015 | 12:03 AM
You need to get behind the wheel and get that break-in period out of the way - then you can find out about breaking the tires loose for yourself.
Old Jul 3, 2015 | 10:34 AM
cheapthrills's Avatar
cheapthrills
I did 113 miles the first day I had my car!
As others mentioned, dig deep into turning off all the nannies and don't launch into the trees.
To Breaking It Loose
