Oil Pressure Concerns
Old Jul 2, 2015 | 03:51 PM
leea_44's Avatar
leea_44
Default Oil Pressure Concerns
New owner (First Vet)
  • 2014 Stingray Base Coupe
  • Manual
  • 27,363 miles
Noticed the last couple of start-ups first thing in the morning, the sound of engine valves tapping but oil level is good. The tapping noise dissipates after a few minutes of driving. I have also noticed oil pressure @ 27 lbs during idle. While idling, oil pressure will rise to about 35 lbs and then drop back to 27 lbs. again. Is this normal?
Old Jul 2, 2015 | 04:01 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
30 psi at idle isn't a problem. Can't comment on the noise without hearing it. It's under warranty though so get it checked by a dealer.
Old Jul 2, 2015 | 04:22 PM
C7&7's Avatar
C7&7
Yea a video of the tapping would be helpful. Oil level is good? Are you sure it's not just the direct injection system making all the noise it does right at start up.
Old Jul 2, 2015 | 04:25 PM
leea_44's Avatar
leea_44
You could be right. I'll get it checked out just to be sure. I'm just concerned about the oil pressure fluctuation when idleling in conjunction w/ the noise.
Old Jul 2, 2015 | 04:27 PM
C7&7's Avatar
C7&7
My oil pressure bounces around some as well when it's warming up. I wouldn't worry too much about that.
Old Jul 2, 2015 | 04:44 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Do an advanced search on this forum (C-7 General Discussion) about tapping noise at warm up. Has been discussed many times. After you review these threads you can make your decision.
Old Jul 2, 2015 | 05:00 PM
DavePowell's Avatar
DavePowell
This is the first engine I've seen that has the engine computer controlling the oil pressure. It's no longer the constant pressure as in other engines.
I was also a little thrown by the voltage regulator being controlled by computer, as voltage on the C7 varies a lot depending on need and engine load.
Dave
Old Jul 2, 2015 | 05:57 PM
Matt-G's Avatar
Matt-G
I hope this is normal as my 2014 Z51 M7 oil pressure does always fluctuate when starting up from cold. I see the oil pressure needle jumping up and down few times and then it stabilizes when the engine warms up. I am not hearing any funny noises tho.
Old Jul 2, 2015 | 06:15 PM
BladeSilver2015's Avatar
BladeSilver2015
My oil pressure does not fluctuate at all at idle.
Old Jul 2, 2015 | 11:17 PM
REDBULLIT's Avatar
REDBULLIT
I just bought a new 15 that now has 200 miles on it, and I see it does the same thing at start up.
To Oil Pressure Concerns
