Car is Dead
Old Jul 6, 2015 | 07:02 PM
z51vett's Avatar
z51vett
The fob in car will not let it shut down so that is what killed it. Don't leave a fob in garage on in room next to garage.
z51vett
Doug
Old Jul 6, 2015 | 09:00 PM
bowtie123's Avatar
bowtie123
Thanks for all the info,
I ordered the Ctek 4.3 today (with cig plug).
I jump started the car yesterday.
After that, the battery was reading 12.3 volts or so.
I connected the GM 3000 tender for about
12 hours and it turned green and was reading 13.3V.
I did not lose any of my settings.
I will see how it does tonight.
Going in for my 500 mile oil change on Wednesday,
will have it checked then.
Thanks again,
Old Jul 6, 2015 | 09:14 PM
24/Eray's Avatar
24/Eray
z51vett
Doug
^^^^^^^^^^ you sure about that? i've left mine in for more almost two years without any issues?
Old Jul 6, 2015 | 09:54 PM
bevo_87's Avatar
bevo_87
Originally Posted by nmvettec7
Buy a CTEK MUS 4.3 Smartcharger 8 Step Charger for under $58.00.
Amazon.com: CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger: Automotive
Connect to the battery directly, wait 2 days and drive the car.
I keep my C7 connected to the CTEK MUS 4.3 Smartcharger 100% of the time when not driving it and NEVER have any electrical issues of any kind.
This is the best $58.00 you will ever spend.
I own 4 CTEK Smartchargers and they have never failed any of my premium sports cars that I own. They always start after sitting a few months without being started.
The CTEK MUS 4.3 will bring a dead battery back to life.
If you doubt this post, buy one, and if it doesn't complete the task, return it to Amazon.com. I am sure you will not be returnng it.
So I better understand this, are you saying you plug this onto your battery every time you park it in the garage? Do you just plug it into cigarette lighter? And it won't damage the battery? I leave my c7 in the garage without driving it for over a week on numerous occasions with no issues so far. Just wonder if I should buy one and start plugging in? Thanks!
Old Jul 6, 2015 | 10:35 PM
nmvettec7's Avatar
nmvettec7
bevo_87:
On all my premium sports cars, Jaguar XKR, Porsche 981, & Corvette C7, I have them all connected to a CTEK Smartcharger.
The CTEK comes new with a eyelet cord. The eyelets on each car are connected directly to the battery. The modern connectors on these sports cars all have 10mm battery posts to the side of the main large battery terminal. Then, I have a CTEK Comfort Extension that is an extra 8'. I simply connect the CTEK connector to the CTEK Comfort Extension. Red eyelet to the red positive and black eyelet to the black negative.
On the C7 I do not use the cigarette adapter located in the hatch.
When I pull into the garage bay I simply connect the 2 ends together and the C7, Porsche 981 and the Jaguar XKR are always being charged.
It takes about 5 secs to connect. The ends just snap together.
I never have an electrical issue of any kind.
Here's a link to the CTEK Comfort Extension plug and play connector.
Amazon.com: CTEK (56-304) Comfort Connect Extension Cable: Automotive Amazon.com: CTEK (56-304) Comfort Connect Extension Cable: Automotive
Here's a few photos of the way the Corvette C7 is connected. I use the same connection for my Porsche 981 and Jaguar XKR.
My CTEK of choice is the MUS 4.3 ....8 Step Smartcharger sold at Amazon for $57.00.
Amazon.com: CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger: Automotive Amazon.com: CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger: Automotive
It is far superior to the US3300 that GM sells for the C7 at $100 as an option called Battery Protection
Old Jul 6, 2015 | 11:20 PM
Jet Vet's Avatar
Jet Vet
St. Jude Donor '15-'16
If you're just going in for the 500 mile oil change the car is almost new and it doesn't matter what the cause was, call the dealership and tell them to send out and install a new battery ASAP.
Old Jul 7, 2015 | 12:34 AM
bevo_87's Avatar
bevo_87
bevo_87:
Thanks for the detailed pics! So the actual unit is in the garage and you have the extension cable through a crack in window? Also do you just have the cable from the battery just laying on the hatch carpet? Just trying to get the full visual.
Old Jul 7, 2015 | 01:09 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Thanks again,
Hi bowtie123,
I am sorry to hear about your experience with your battery and would be happy to reach out to the dealership on your behalf. I can let them know about your battery concern and help schedule an appointment for the oil change and battery diagnostic.
If this interests you, please send us your VIN, current mileage, contact information and preferred dealership.
Kind regards,
Kaylee D.
Chevrolet Customer Care
Old Jul 7, 2015 | 01:35 PM
Boiler_81's Avatar
Boiler_81
I agree, leaving the fob in the proximity of the car should not cause the battery to die. Typically the logic in the module is such that it will go to sleep if there is no activity even if the fob is present. Something else caused the battery to drain. I would take it to the dealer and have them check it out.
ratman6161's Avatar
ratman6161
I've got a different brand of smart charger but I use the same sort of setup. Yes, I just have a short cable with the connector on it peeking out from under the carpet in the hatch area. FYI if you are using the type of tender AKA maintainer that goes in a 12 volt (cigarette lighter) outlet, it has to be the one in the hatch area near the battery. That's the only one that's live when the car is off.
Old Jul 7, 2015 | 01:59 PM
bowtie123's Avatar
bowtie123
The Battery held it's charge overnight.
Can anyone explain the connections on this battery?
The connections are different than the pictures posted
earlier in this thread.
Are the Z-51 battery connections different than a non Z-51?
Thanks for any info.
Old Jul 7, 2015 | 02:31 PM
grandpawmoses's Avatar
grandpawmoses
Of course that's the negative on the right, the positive on the left hand has several fused connections. There are two 100 amp circuits and one 350 amp circuit to the engine compartment. There are two unused 100 and one unused 60 amp circuit taps.
I'm not sure but I don't think there is any difference between the base/Z51 connections. The previous picture should be the same, it just has the cover over the positive terminal in place and shows his battery tender connections.
Old Jul 7, 2015 | 03:09 PM
  #33
bowtie123's Avatar
bowtie123
Thanks for the info.
Never seen connections like that before.
Old Jul 7, 2015 | 04:15 PM
  #34
KANUK's Avatar
KANUK
Cruising
Its always in the car when in the garage,
as are the keys to my other cars.
When I go somewhere and park it, then I remove it.
I would rather have a good old fashion key.
I do not want to derail this thread, but- as a retired Fire Captain--It sure was nice when responding to a garage fire with vehicles inside that on occasion the keys were in the ignition--usually saved those cars-those without went up in flames as steering locked and car in park made it a task not even attempted as fighting the fire was more important.
Old Jul 7, 2015 | 08:28 PM
  #35
bob guzzy's Avatar
bob guzzy
Something people should be aware of is the positive battery terminal does not come off, when you loosen the 10mm bolt on the cable end.
There are 2 plastic catches, one on either side of the battery, released from the top with a flat screwdriver.
Be careful with this one, it looks like its going to be pricy.
Old Jul 7, 2015 | 09:19 PM
  #36
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
I bought my Z06 from Georgia and it arrived dead! Did all the crap you did. Battery tender blah blah.
Not sure what was running, but I could hear the faintest motor running.....but let me get to the punch line.
Disconnect the battery. Let it sit for a day or two, reattach and you will immediately notice the interior lights come on. Car will fire right up.
I don't know what caused it other than I think something didn't shut down correctly and drained the battery. But new car, new battery so it was able to recover...,no problem since then.
Good luck!
Old Jul 7, 2015 | 10:06 PM
  #37
nmvettec7's Avatar
nmvettec7
Yes, I keep the CTEK MUS 4.3 plugged into the C7 all the time when not driving. Once I pull the C7 into the garage the CTEK gets connected. It takes about 10 to 15 minutes to bring the battery back up to a full charge and for all the lights on the 8 Step smartcharger to light up. As you can see in the photo below, only 3 lights have lite up on the CTEK unit. I need to see 7 led's light up. Then it's fully charged. The 8th LED only lites up if the C7 has been sitting idle for more than 8 days. Then the unit goes into a float mode.
No. See the attached photos I have added to this thread. It's simply a plug in and connect. The cord comes out of the rear hatch. The hatch closes over the cord without any damage to the rear hatch rubber moulding.
All CTEK units sold come with the eyelet connector cord or an alligator clip cord. I use the eyelets connected to the 10mm battery posts as seen in the photos above. While the 10mm battery post nut is not fully removal, I simply clipped the eyelet open and slipped the eyelet onto the 10mm post and tightened down the nut to secure the connector.
Here's a few more photos to provide how the final connection is made. You can see the connection cord from the battery comes out against the rear hatch wall and my extension is plugged into the connector and runs out of the rear hatch.
Hope these help answer a few more questions.
To Car is Dead
Old Jul 7, 2015 | 10:25 PM
  #38
bowtie123's Avatar
bowtie123
Is it possible that a call to On Star I made, failed to disconnect
and drained the battery?
It appears to be holding a full charge now.
Old Jul 8, 2015 | 11:48 AM
  #39
pdiddy972's Avatar
pdiddy972
Why are these cars requiring a battery charger be hooked up? I can leave my 370Z for days on end and it's fine (and previously my Infinitis). What's eating the charge on Stingrays making this necessary?
Old Jul 8, 2015 | 11:52 AM
  #40
Glen e's Avatar
Glen e
The new c7 is like all new cars , after about a month, it needs a charge...up untill then, its fine. And after that, you can simply pull the neg lead and lock the car, all the major settings hold, i just did 6 weeks that way.
