PDR stop working
Old Jul 7, 2015 | 03:46 PM
luczaj30's Avatar
luczaj30
7th Gear
Default PDR stop working
Hi, today my PDR stop working, when I push the PDR icon on the screen is not responding, I try to push and hold it all it does it change the colour to red. I have it for two months without any problems,not sure what happened, anyone expiriance this problem? Any advice would be appreciated, thanks.
Old Jul 7, 2015 | 04:02 PM
USMCVETC7's Avatar
USMCVETC7
Check to make sure your memory card is all the way in. Pull it out and then push it back in again to insure it is seated properly. Worth a try??
Old Jul 7, 2015 | 04:31 PM
luczaj30's Avatar
luczaj30
7th Gear
Hi, I try it twice, nothing changes, still not working, but thanks for advice
Old Jul 8, 2015 | 02:06 AM
RonC7's Avatar
RonC7
is the memory card full?
Old Jul 8, 2015 | 11:41 AM
Heidemarie's Avatar
Heidemarie
I had same problem initially. SD card had to be replaced after a faulty battery in our new 2015 vette was replaced; Radio Shack stated the battery failure damaged SD card. Try to find someone with a corvette that has a PDR and see if your card works there; if not, you need a new SD card - problem solved.
Hope that helps.
Heidi
SAVE THE WAVE
Old Jul 8, 2015 | 11:44 AM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
I'm having the same issue. I push the PDR icon on the main screen and all I get is a black, blank screen.
It did work before and I did try pulling SD card out and back in.
I would think that if it was an SD card issue, you'd still be able to get to the PDR screen.
Old Jul 8, 2015 | 12:32 PM
dosamp's Avatar
dosamp
I had the same problem, worked OK then the black screen.
I got it working again by re-formating the SD card.
Old Jul 8, 2015 | 01:41 PM
CriticalmassGT's Avatar
CriticalmassGT
SD cards can be finicky and need reformatting or replacing from time to time.
Old Jul 8, 2015 | 06:04 PM
BradSW's Avatar
BradSW
OK, I pulled the SDcard (Sandisk Ultra 32GB), put it in my computer and it worked fine. I've only recorded 2 times and have 27.0 of 27.9 free. I reformat anyway, made sure I reinstall while car is running, but still black, blank screen when I push the PDR icon. Ejected and reinstalled several time to no avail.
It goes in tomorrow for oil change and the PDR update, maybe the update will fix things......I hope.
Old Jul 8, 2015 | 08:43 PM
luczaj30's Avatar
luczaj30
7th Gear
Hi, thanks to all advices. What I find out it was a very hot temperature outside. It was 36 C; when I live my car at a parking lot with a Vale on, after about 30 minutes in my garage with open windows the PDR starts operating normal, so I have decided to check that again. Took vette out on open sun lefted windows closed and put my PDR in Vale mode and live it for 10 minutes, when I came back same story , PDR not working. Today temperature drop down to 24 C, did same think for 5 times and everything works just fine, not sure if someone have expiriance a heat problem with PDR, but in my case very hot temperature outside Is definitely making my PDR to stop working.
Old Jul 9, 2015 | 09:10 AM
BradSW's Avatar
BradSW
Mine is always garaged (home and work) and the temps here are low 80s......still dead screen on PDR.
Old Jul 9, 2015 | 06:46 PM
BradSW's Avatar
BradSW
Car been in shop all day.....still can't get PDR to work. Talking with GM they are looking at replacing PDR module and the screen.
More tomorrow......
Old Jul 10, 2015 | 05:27 PM
BradSW's Avatar
BradSW
Well, the conclusion is, working with GM engineering, that the screen needs to be replaced. This doesn't make much sense to me since the screen works fine for everything else..
We shall see.
Old Jul 11, 2015 | 12:32 PM
BradSW's Avatar
BradSW
Picked up the car for the weekend so in my garage.....
But GM must really think it is the screen as they overnighted a new one to the dealer to arrive on Monday........I'll post the results.
Old Jul 14, 2015 | 10:03 PM
BradSW's Avatar
BradSW
New screen installed today and the PDR works again. Apparently, there are a lot of electronics built into the screen assembly and the input failed.
Had the update done also....haven't had a chance to use it, but will give it a shot.
Done with this issue.
Old Jul 15, 2015 | 09:34 AM
Woodson's Avatar
Woodson
I shudder to think what that would have cost without a warranty.
Old Nov 4, 2019 | 09:15 AM
rmccracke's Avatar
rmccracke
5th Gear
Joining the list of C6 (2007) owners whose time went blank on the navigation system. I did not change the battery or disconnect it. I just disappeared along with the GPS time as well. Everyone else on the Radio and Navi work fine. I am guessing we still waiting on GM for a fix
To PDR stop working
