Windshield wipers
Old Jul 11, 2015 | 05:32 PM
Jksvette's Avatar
Jksvette
Cruising
Default Windshield wipers
The wiper on the passengers side sticks out about 4 inches higher than the drivers side anybody else notice this on there car?
Old Jul 11, 2015 | 05:42 PM
Larry/car's Avatar
Larry/car
That is the way it is. I noticed that under certain rain conditions the intermittent selection could cycle a little faster. The wiper on selection is to fast and intermittent to slow. Should have one more in between selection. My work car does.
Old Jul 11, 2015 | 05:45 PM
dvilin's Avatar
dvilin
It is normal.
Old Jul 11, 2015 | 09:00 PM
meyerweb's Avatar
meyerweb
You do know that the intermittent cycle speed is adjustable, right? On the shortest interval, it's almost as fast as the lower wiper on setting.
Old Jul 11, 2015 | 09:42 PM
Larry/car's Avatar
Larry/car
Yes, the shorter interval is still longer than my daily driver. And I miss that speed, not a big deal.
Old Jul 11, 2015 | 09:54 PM
BJ67's Avatar
BJ67
Yes its the way its set up from the factory. I loosened mine and dropped it down. It now sits right on the top of the filler panel below the windshield. The only thing you need to be carful of is when you pick up the wiper arm and blade to clean the windshield (hood open)
be careful when you pick it up or put it down, the blade will hit the fender if you forget to hold it away when putting it up or down.
Old Jul 11, 2015 | 10:45 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
Yep, but at least you can move them both out of the way, unlike the C6.
To Windshield wipers
