First 1,000 miles and down a quart-normal?
Old Jul 12, 2015 | 10:37 AM
Corgidog1's Avatar
Corgidog1
Default First 1,000 miles and down a quart-normal?
I got my car in April 2015 and have 1000 miles on it. It is a base not a Z51. I checked my oil level for the first time today and saw no oil on the dip stick. I added about a quart till the dipstick showed 2 bars on 1 side and up to the cross hairs on the other side so I gather it was down a quart in the first 1000 miles.
Is this normal?
Should an engine oil low message light appear when the engine oil is low? The manual says this happens "on some vehicles". Are they referring to the Z51, the Z06, or the base?
So I have 2 questions.
Old Jul 12, 2015 | 10:39 AM
juanvaldez's Avatar
juanvaldez
No, and you won't get a low oil pressure light 'til your engine is toast.
Old Jul 12, 2015 | 10:47 AM
owc6's Avatar
owc6
Oil consumption during engine break-in is normal, some even have quite a lot. It should be checked every fuel stop.
On the C6, the wet sump has a warning light at about 2 quarts low, but the dry-sump apparently doesn't. I don't know if they added a warning light to the C7 dry-sump or not. It would be nice to find out if it does, or if they didn't add this. With the added tank, it may be difficult for the car to measure it like it does on the wet-sump.
Old Jul 12, 2015 | 10:52 AM
Red C8 of Jax's Avatar
Red C8 of Jax
This has been discussed many times on the forum. The answer to your first question is NO. I would keep an eye on my dip stick and discuss this with the dealer at my first oil change. I have 7000 miles on my C-7 and my engine has never used any oil.
Old Jul 12, 2015 | 11:01 AM
BlueDevilZ51's Avatar
BlueDevilZ51
Yes, a little oil consumption is normal until the rings are seated.
Old Jul 12, 2015 | 11:03 AM
Glen e's Avatar
Glen e
I personally don't consider a full quart down in 1000 miles to be a normal oil burn.
Old Jul 12, 2015 | 11:45 AM
Patman's Avatar
Patman
I think he meant a low oil level warning though, not low oil pressure. My C5 had a low oil level warning that would come up on the DIC when the level was about a quart and a half low. I think my C6 has the low oil level sensor too, but I haven't heard of one on the C7 so they probably got rid of it?
Old Jul 12, 2015 | 11:50 AM
CdnC7's Avatar
CdnC7
mine has never consumed any oil.
Old Jul 12, 2015 | 12:01 PM
thrilled's Avatar
thrilled
I had to put A quart in after 600 miles.Since then have had oil changes and hasn't been low since.Now it's over 7000 miles.
Old Jul 12, 2015 | 12:11 PM
Corgidog1's Avatar
Corgidog1
I don't feel so bad now.
Dads dream's Avatar
Dads dream
Just checked mine at 1,017 miles level is good....non z51....base coupe
Old Jul 12, 2015 | 12:48 PM
oldfoggy's Avatar
oldfoggy
Glen; 357@4000 last week. Exactly 6 weeks between the 15 & 16, can't wait. Thanks for all you support.
Old Jul 12, 2015 | 01:10 PM
owc6's Avatar
owc6
Page 9-18 of the dreaded OM says it's normal for higher oil consumption during engine break in .
Old Jul 12, 2015 | 01:31 PM
Larry/car's Avatar
Larry/car
My base car used oil first two thousand miles (about 1 1/2 quarts). Now at 3,500 miles, oil consumption is non existent. Some technitions claim a new engine should use oil, the cylinders will seal better and the end result will be an engine that produces rated or better power. "Whatever" after a few thousand miles consumption should stabilize with little or no measured oil use. Don't stress!
Old Jul 12, 2015 | 01:38 PM
juanvaldez's Avatar
juanvaldez
It is not normal. I have owned dozens of small blocks. I would check the oil every day in the same spot first thing in the morning. When it is down top it up to the full mark and keep a record of the date, mileage and oil added. What the manufacturer calls normal is ridiculous. Do you really think adding 5 quarts between oil changes is normal?
Old Jul 12, 2015 | 01:54 PM
StFarmer's Avatar
StFarmer
How did you check the oil? Did you let the engine warm up to operating temp, shut the engine off and wait 5 to 10 minutes before checking the oil? This is the proper procedure for checking the oil on a dry sump system.
If you checked it with the engine cold, it's normal for no oil to show on the dipstick.
Old Jul 12, 2015 | 02:07 PM
C2367's Avatar
C2367
You may want to install a catch can to see how much oil is removed before it gets ingested into the manifold. It would be a good idea anyway to help prevent future intake port / valve deposits from accumulating and reducing power.
To First 1,000 miles and down a quart-normal?
Old Jul 12, 2015 | 02:18 PM
thrilled's Avatar
thrilled
My oil level is the same cold or hot.base C7
Old Jul 12, 2015 | 02:21 PM
Joy c7's Avatar
Joy c7
His is a base.
Old Jul 12, 2015 | 02:23 PM
StFarmer's Avatar
StFarmer
Sorry, I misread your original post and thought you had the Z51.
