How do you turn NPP exhaust on in Touring mode?
Turn the engine sound management OFF. Then it will always be as loud as it is able.
If you turn ESM off (on a 2014), it will work the same as in track mode, I believe. On the 2015, you don't have on/off, you can set ESM to Stealth, Sport or Track. If you choose Sport or Track, it will act just as if you had selected those modes on the ****.
My 2015 doesn't drone in any mode. I have it set to Sport in the settings and it is always closed (quiet) at cruise. Track mode stays loud a bit longer at cruising speeds than I like, but Sport is the sweet spot for me.
F4 Phantom, is your car a '14 or a '15? as meyerweb mentioned, in the "Sound Management System" if you have a '14, make the OFF selection, and it will work the same as in track mode. if you have a '15, you can either place it in AUTO, which will change the exhaust based on what mode you have the selector switch in on the console OR you can "PIN" the exhaust on ONE mode by selecting it. I personally have mine pinned in TRACK mode......and seeing as I have an automatic, as soon as the AFM kicks in on the highway....it gets real quiet....but when you jump on it....ITS ON!!
