Tires
Old Jul 22, 2015 | 10:33 AM
James Bertuca's Avatar
James Bertuca
Default Tires
What is a good air pressure to run in everyday, city & highway use ?
I know it's mark for 30 psi.
Old Jul 22, 2015 | 10:37 AM
Larry/car's Avatar
Larry/car
30 psi cold as stated in operators manual
Old Jul 22, 2015 | 10:45 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
and if you forget and don't have the manual when ready to adjust it's also on a sticker on the drivers door panel as it is in most cars!
Just be sure the tires are a room temp or called cold. The pressure increases to 32 to 33 psi after driving a short while in normal driving.
Old Jul 22, 2015 | 10:48 AM
TEXHAWK0's Avatar
TEXHAWK0
Believe it or not, there was a news story reporting that an unusual number of people have had tire failures due to the record heat.
It might be worth noting what the temperature (and pressure) swings are for extreme conditions... so max. tire pressures are not exceeded.
Old Jul 22, 2015 | 11:04 AM
JerryU's Avatar
JerryU
Good point! Yesterday it was 100 and tire pressure increased ~ 4 psi when driving on the interstate. Calculates back to a tire temp of ~120 to 130 F, which seems reasonable.
Old Jul 22, 2015 | 12:21 PM
bob guzzy's Avatar
bob guzzy
I air up to 28 they come up to 30 with use, I watch the tires very closely, if I can rotate them on some cars I do it frequently.
Old Jul 22, 2015 | 03:19 PM
meyerweb's Avatar
meyerweb
The factory recommendation for the Corvette, as for all other modern cars, is 30 psi COLD, not hot. The manual says
Check the tire
inflation pressure when the tires
are cold, meaning the vehicle
has not been driven for at least
three hours or no more than
1.6 km (1 mi).
You are under inflating your tires.
Old Jul 22, 2015 | 03:44 PM
scottsh's Avatar
scottsh
My tires came from the dealer set to 38PSI - it was crazy. I reduced that immediately to 30 (cold) as soon as I saw it.
Old Jul 22, 2015 | 04:50 PM
James Bertuca
That's another reason why I asked.
Old Jul 22, 2015 | 04:59 PM
meyerweb's Avatar
meyerweb
Mine came with each tire at a different pressure, and all four too high. And this was from a highly rated forum dealer.
Old Jul 22, 2015 | 07:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I think it depends on where you live and the climate at the time. Yes, to 30 lbs. cold, but just driving around the block can raise pressure by a pound sometimes. Don't forget that about every 10 degree swing in outside temp will change your tire pressure about 1 lb., up or down. That means, depending on where OP lives, you could have 30 lbs. cold one month and be under or over in a couple more. Keep an eye on your tire pressures.
Old Jul 23, 2015 | 07:37 AM
LIStingray's Avatar
LIStingray
I can't be bothered constantly adjusting tire pressures, so mine are set to 30 psi at 70 degrees - which is what my climate controlled garage is usually at. I will deal with the tires being 32 psi on an 90 degree summer afternoon and 28 psi when it is 50 degrees out in the spring and fall.
Old Jul 23, 2015 | 07:50 AM
rcooper's Avatar
rcooper
St. Jude Donor '15
My climate controlled driveway helps me keep mine at 30 pounds while cold.
Old Jul 23, 2015 | 08:24 AM
James Bertuca
Well let me ask this question, when checking your PSI do you use your DIC or check the individual tires?
Old Jul 23, 2015 | 09:12 AM
owc6's Avatar
owc6
At first, you should use both so you can see how accurate your DIC is reading. Once you know it's reading accurately , you can rely on the DIC for tire pressure when driving, BUT you should always use a hand-held when adding air, or releasing, because the DIC will NOT be accurate when the car is not moving--it doesn't sample the tire pressure often enough to give you an accurate moment to stop adding or releasing air.
Old Jul 23, 2015 | 09:32 AM
C7cmnthru's Avatar
C7cmnthru
Seems to me this is being made way too complicated. Maintain air pressure per the manufacturer's instruction. Over and under inflation affects tread wear and tire performance. Check the max pressure on the tire side wall. You will not get there in normal driving. Your tires will not explode. With all due respect, the suggestions on what pressure to run (other than the manufacturer's spec) are not based on any measured testing under controlled conditions (as GM and Michelin would do).
Old Jul 23, 2015 | 10:34 AM
1SG_Ret's Avatar
1SG_Ret
To Tires
Old Jul 23, 2015 | 10:49 AM
kenownr's Avatar
kenownr
MINE TOO
Old Jul 23, 2015 | 11:16 AM
Len44's Avatar
Len44
When I did the Museum delivery in late February, the weather was pretty darn cold. Tires were at 30 psi all around. I've checked a few times since with a quality tire gauge (cold, of course), at various ambient temps. All four still read 30 psi to date, a bit of a surprise to me, (but I like it).
If one were to plan a road trip of approximately 800 miles, is it prudent to slightly elevate the psi to, say, 33-34 psi before starting the trip? The issue here is flex, which builds heat a bit more than a tire that flexes less. Would the higher starting psi result in less heat buildup?
Similar question: Would the amount of the rise in psi be more, less, or the same if starting at 30 psi on the road trip, compared to starting at 34 psi?
Counting on the collective wisdom of Forum members to help me sort this one out. Thanks, in advance.
Old Jul 23, 2015 | 11:22 AM
tunaman's Avatar
tunaman
^^^THIS^^^ Best to follow manufacturer's instructions for street and track use.
