Ouch! How do I fix this?
Old Jul 25, 2015 | 09:42 PM
coupeguyz51's Avatar
coupeguyz51
Default Ouch! How do I fix this?
So, I don't know how this happened...it looks like the scratch came from back to front? Best I can figure it was a piece of truck tire recap trash that appeared from under the suv in front of me before I could avoid it...heard a loud bang when I hit it, but no front end damage... anyway, will Dr Colorchip work or will it require a trip to the body shop? Scrach is not deep
Old Jul 25, 2015 | 09:44 PM
mtraylor2001's Avatar
mtraylor2001
where exactly is the scratch? Zoom out a bit
Old Jul 25, 2015 | 09:47 PM
bob guzzy's Avatar
bob guzzy
You can rub it with clear coat compound first, then touch up what you can't take out
It's hard to get a good look at just what you have, without a few angles but touch up will help hide some of it for now.
Old Jul 25, 2015 | 11:07 PM
WelderGuy's Avatar
WelderGuy
I have no idea what part of the car is shown in the picture.
Old Jul 25, 2015 | 11:24 PM
coupeguyz51
Well, I'm not sure why it is relevant as to how to fix it, but this shot is from right behind the left front wheel....
Old Jul 25, 2015 | 11:35 PM
TBD's Avatar
TBD
Default Huh?
There is not a thing I can see on my Corvette that looks anything like this. Three (3) colours of something. Is this from under your car? If so, who could possibly see it?
Peace, out.
Old Jul 25, 2015 | 11:45 PM
coupeguyz51
Peace, out.
well, as I said, it is just behind the front wheel on the drivers side....the towel covers the wheel which was just washed so it does not pick up dust while sitting in the garage....yes it is down low, but definitely noticeable....
Old Jul 25, 2015 | 11:46 PM
coupeguyz51
Peace, out.
the grey thing next to the towel is the front mud guard...which will be replaced.
Old Jul 25, 2015 | 11:47 PM
Skidplate's Avatar
Skidplate
Add some more **** carpet.
Old Jul 26, 2015 | 09:23 AM
Larry/car's Avatar
Larry/car
I would get GM touch up paint and carefully paint the scratches with a sharpened toothpick. Take your time to keep the paint within the scratch. Then after the paint dries use a polishing compound and smooth the paint. Paint and compound until satisfied with result. When you are finished it will be virtually impossible to see. Finish with your favorite sealant/wax.
Old Jul 26, 2015 | 09:26 AM
TBF's Avatar
TBF
Coupguy - I would love to help you but you really need to show a picture of the car that we can recognize. It makes a big difference in recommending a fix.
Old Jul 26, 2015 | 09:30 AM
WelderGuy's Avatar
WelderGuy
Old Jul 26, 2015 | 10:42 AM
coupeguyz51
Here's a farther away shot. TIA
Old Jul 26, 2015 | 10:48 AM
nmvettec7's Avatar
nmvettec7
Remove the splash guards, all four, and paint them body color so they all match.
The one that is damaged can be sanded down lightly and painted.
Or just replace the guards......in the front about $60.00 from CF vendor
gmpartsdirect.com
As for the damage on the colored body part/panel. Try the Dr. Color Chip.
Old Jul 26, 2015 | 10:52 AM
TEXHAWK0's Avatar
TEXHAWK0
Looks like there is white on the fender and the splash guard, so it may just be paint on the surface that will polish out..
I would try a light polishing compound first...
Old Jul 26, 2015 | 11:26 AM
hawkgfr's Avatar
hawkgfr
New splash guard thingy and a little rubbing with the right compound and buff and good as new...
Old Jul 26, 2015 | 11:46 AM
Black&White's Avatar
Black&White
Yea I agree order a new set of front splash guards and some clear coat safe polishing compound and you will be good to go. You could even repair the splash guard if you wanted by sanding it then painting it with semi flat black spray paint.
To Ouch! How do I fix this?
Old Jul 26, 2015 | 11:49 AM
dvilin's Avatar
dvilin
Then drcolorchip, wax, buff and should be fine.
Old Jul 26, 2015 | 03:25 PM
coupeguyz51
Thanks for all those who responded with real suggestions. That's what I love about this forum...after the clowns take their shots, you eventually get some solid advice!
Old Jul 26, 2015 | 04:11 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
If the DYI approach doesn't work, try a local body shop and ask them for an out of pocket cash price. May have to replace the trim piece but let the body shop guys have a crack at it first.
Good luck with your fix. Same thing happened to me but the piece of tire caught the lower lip of my front bumper. The scratches went down to the material past the clear, paint, primer, so a body shop did mine, cash job, looks like new.
