Run Flat? Firestone?
Wow,
So I just hit 18000 miles in my 2014 Corvette. My tires are about 1000 miles past done. Tirerack is only showing Michelin and Bridgestone for the C7. After cross referencing the size I found a set of Firestone firehawk run flats for about $400 less than the Michelins. The only issue is on Tirerack it says for C6 only. I don't know why the tire wouldn't work on a C7.
Any ideas? Anyone running Firehawks on a C7? Since these wear out so quickly I wouldn't mind saving some money if the Firehawks are good.
Mike
Mike
Wow,
Mike
Mike
I just replaced my Michelin Run-flats with Bridgestone S-04 Pole Position tires. These are not run-flats! Read the reviews on the Tire rack website and I think you will find them a great replacement tire. Discount Tire has them on sale now for a great price. I have the non-Z51 which has 18' & 19" tires. Out the door price with mounting, balancing, replace TPMS valve stems, sales tax.......$888.10! I opted not to take the optional warranty which was $23/tire. These tires should be quitter and Tire Rack testing indicates they are excellent performance tires in all categories. Customer reviews also reflect the same!
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
Wow,
Mike
Mike
I too am thinking about ditching the run-flats when the stocks wear out. However, I don't like the idea of being stranded in the event of a tire failure so I'll carry around what came with my M3, an ///M Mobility kit, which is basically fix-a-flat and an air compressor which will get you to a tire shop so you can do a $10 plug.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Wow,
Mike
Mike
Pointing at a C6 (19/18") only, might be a size issue if the Z51 is involved. There are non-runflat tires in the A/S series of Michelin that you could use but I'm with you on replacing a run flat with another run flat.
Elmer
I have a 2014 Z51 convertible with every option. I swapped out the OEM Micheline summer run flats for the Micheline Pilotsport A/S 3's which were highly rated. The car rides much better!!! It's not a run flat so I carry a small compressor and a repair kit, plus I have a wheel/tire warranty and AAA in case of problems.
I'm on my third car without a spare, and carry the Slime compressor kit.
http://www.walmart.com/ip/14254126?w...493672&veh=sem
I appreciate the input. I guess I've been buying cheap tires too long for my other cars. I too had considered going non run flat but they have saved me a tow on three occasions. In fact Run Flat's saved my butt on one of those occasions while rolling at twice the State's recommended speed.
I use my Corvette's for commuting to work on back roads and there are parts of the road(sans traffic)where I can add velocity to my morning Red Bull.
Glad to see Michelin got into the game on the C7. Goodyear has owned Corvette for a long time. Would be nice if there was a price and product war between the brands for us consumers. I remember my first Corvette(1981) had Goodyear Eagle GT's. At that time those tires were very advanced and super soft compound. I tried BFG's once and took them back to the tire shop for the Eagles.
All in all $1400 to keep my car to spec and my foolish middle age buttocks safe ain't that bad of a deal...
msaporetti
msaporetti
