Transmission RPM Problem
Old Jul 28, 2015 | 03:07 PM
champ_85's Avatar
champ_85
Default Transmission RPM Problem
I have a '14 auto C7 with 10k miles. If I gun the engine on the freeway and have the RPM's increase from 1.5k to approx. 4-5k, when I release the peddle, the RPM's will sometimes stay at the 4-5k level for 10-15 seconds even tho my foot is off the accelerator (this typically happens when I go from 55mph to 80mph to get on the diamond lane and then let of the gas peddle. This same problem sometimes occurs when I paddle shift from 1st up to 3rd quickly. Once again the RPM's won't drop in 3rd gear even when my foot is off the accelerator. As always, this is an intermittent problem that can never be duplicated at the dealer Anybody out there had this problem?
Old Jul 28, 2015 | 04:26 PM
RicK T's Avatar
RicK T
You haven't provided quite enough info to be sure but I think this is what you are experiencing, normal programmed behavior:
https://www.corvetteforum.com/forums...eleration.html
Old Jul 28, 2015 | 04:47 PM
tunaman's Avatar
tunaman
Yep... Performance mode kicks in. It wants to play some more!
Old Jul 28, 2015 | 06:30 PM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
I likey performance mode!
Old Jul 28, 2015 | 06:52 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The first time it happened to me was a WTF moment. After I realized it just wanted to keep playing, I was all good with it.
Elmer
Old Jul 28, 2015 | 08:37 PM
Marcus Nakamura's Avatar
Marcus Nakamura
If you want to get out of it hold the + paddle for about 3-4 seconds and it will go back to normal drive mode
To Transmission RPM Problem
