Undergoing Full Dash Replacement
Old Aug 9, 2015 | 07:44 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Originally Posted by VictorBarron
All I can say is holy *****!! It is disturbing looking at all the pictures.
When they are finished, I would go over every inch of my interior and exterior and make sure I didn't have any scratches, scuffs or other damage. I would also have the tech who did the dash replacement or the service writer, go with me for a test drive before I signed any paperwork. Make sure you don't have any rattles coming from the dash.
Old Aug 9, 2015 | 08:01 PM
BladeSilver2015's Avatar
BladeSilver2015
Read my previous post. I can guarantee you that your car will never be the same. I was upset when parts of my 84 were scattered all over the shop but that dealer never used my car as a storage shelf. I cannot believe what I am seeing here. Once it is back together I would dump the car as quickly as possible.
Old Aug 9, 2015 | 08:38 PM
TCRVETTES's Avatar
TCRVETTES
2024 C8 of the Year Finalist - Modified
I have 14 z51 3LT. At some time during the build a drop of glue got on the dash pad. The dealer was not able to clean off the glue. My eyes went to the glue spot every time I got in the car, so my dealer ordered a new dash pad. The rear hatch also had a flaw that looked like a dent between the rear window and the back edge of the hatch. I told my dealer I did not want this filled and painted. We got the plant to send a new hatch that was already painted. It took a few phone calls to customer service, but a new hatch and dash pad arrived.
It took the tech two days to do the dash. After talking with them about my concerns with the hole dash being apart, I asked if everything would work again. The tech said that during the replacement he found several screws that had been stripped which he repaired.
8000 miles later all electronics work, no rattles or squeaks and the new dash and rear hatch look great.
I hope your dash replacement is as good as ours is. Good luck.
Old Aug 9, 2015 | 10:24 PM
roadsterboy's Avatar
roadsterboy
I cant help myself, but I would have gone all Joe Pesci when seeing stuff on my roof, hood, rear or ANYTHING. There would be more f bombs going off that they ever heard.
Old Aug 9, 2015 | 11:54 PM
Originally Posted by tunaman
Whether the top can handle the load or not is moot... A professional shop should not be using a customer's top as a work or storage bench.
OP - good luck with the repair - hope all goes well.
Old Aug 10, 2015 | 08:42 AM
Casey VP26's Avatar
Casey VP26
Originally Posted by Shhhh
So the leather on my 3lt was already coming up around the vent by the window which looks like it shrunk. Evidently the only way to remedy this was to order a new dash and do a full dash replacement. I keep my car in the garage and when it's out and about I keep a sunshade up at all times.
I'm pretty terrified after seeing the inside of my car completely dismantled. Has anyone else had to go through this? Also how did it turn out?
This has also lead to another question. I've strictly followed the user manual of not using any leather product on the leather and only using a damp microfiber cloth. Should I have used some sort of leather conditioner? Is the manual wrong? What do you all do for your leather care?
Thanks!
Can you tell me how old is your car, Thank You.
Crossed Flags Fan's Avatar
Crossed Flags Fan
Default Yikes
Can't believe they put those parts on the convert top......
Old Aug 10, 2015 | 09:03 AM
1SG_Ret's Avatar
1SG_Ret
Often times I find it easier on me to not know how things are accomplished during a building or repair project. Usually the more I observe, the more unsure I am of success.
Now, I pretty much drop things off and wait for the call to come pick them up. As long as the repair fixes the problem and the item is returned looking like it did prior to arrival in all other regards, I'm fine with it. What happens in the garage, stays in the garage.
You can make yourself crazy trying to stay in the loop.
Old Aug 10, 2015 | 09:07 AM
W88fixer's Avatar
W88fixer
Originally Posted by NSC5
Using your convertible roof to hold parts doesn't give me a good feeling about this dealer process.
That was my first thought, seems an invitation to scratching the top fabric. Don
Old Aug 10, 2015 | 10:00 AM
Red C8 of Jax
100%
Old Aug 10, 2015 | 10:03 AM
Shhhh's Avatar
Shhhh
It's a 2014 z51 3lt.
To everyone: Since the dash is apparently plastic coated and leather conditioner won't make it to the leather, I would love some suggestions to how I can prevent this from happening in the future.
Old Aug 10, 2015 | 12:42 PM
iclick's Avatar
iclick
It goes against my grain not to put some sort of chemical on my leather and vinyl, and after much time researching the topic I've resigned myself to using a damp microfiber cloth as the manual recommends. Vinyl preservative with silicone isn't a good idea because the vinyl coating is porous and silicone is bad for leather, and leather conditioner isn't good because not enough of it soaks into the leather to do any good and it isn't ideal for vinyl. Leather conditioner also usually has oils which mostly sits on top the vinyl and does no good. I'm waiting for an enterprising company like Lexol to come out with an appropriate conditioner for this type of leather, but if it exists today I'm not aware of it. In the meantime leather maintenance is going to be wiping it down periodically with a damp microfiber cloth.
Old Aug 10, 2015 | 02:10 PM
  #33
Shhhh's Avatar
Shhhh
Just received the call stating it's ready for pick up. Fingers crossed.
Old Aug 10, 2015 | 02:26 PM
  #34
VictorBarron's Avatar
VictorBarron
Give us the verdict
Old Aug 10, 2015 | 03:03 PM
  #35
Jimbob26's Avatar
Jimbob26
Was that a peanut butter sandwich I saw on the console?
Old Aug 10, 2015 | 03:51 PM
  #36
jedblanks's Avatar
jedblanks
Originally Posted by stingraymyway
They'd be replacing the cloth top and anything else, if there's any sign of damage.
and likely storing the unassembled top pieces on the dash or seats -- leading to a never-ending cycle.
OP if you watch the videos on youtube showing corvette assembly, you will see that the dash is assembled outside the car and put in as one unit before the windshield and before the seats. Disassembling the car in the manner shown is going to lead to problems.
Old Aug 10, 2015 | 03:58 PM
  #37
bbcb's Avatar
bbcb
Are you kidding me !!!! Those photos make me cringe ...
I would tell them keep the car !!! Send those photos to gm and your lawyer ...
To Undergoing Full Dash Replacement
Old Aug 10, 2015 | 04:00 PM
  #38
alienranch's Avatar
alienranch
I'm with everybody else. What the hell are they using your vert top as a damn cart for?
Old Aug 10, 2015 | 07:41 PM
  #39
Shhhh's Avatar
Shhhh
So there were a few issues. The part around the steering wheel was left open, I could see space / clips under the strip on the right, and they scratched my steering wheel.
While I appreciate everyone's passion for their car and understand how easy it is to get angry at the way this was handled, I didn't feel confrontation would yield the most favorable results and only lead to further confrontation. The service mgr was out last week, the guy that knew was acting mgr at the time. The real mgr was in today, and I showed him the issues in a calm and courteous manner. They corrected two issues already and ordered a new steering wheel for me. He was nice and sympathetic.
I went for a ride and so far so good. No creaks and everything lines up well.
Steering wheel scratch. There is another on the side.
Hopefully after the wheel is replaced all will be well. I don't see any damage to the convertible top or the rear.
Will update periodically.
Old Aug 10, 2015 | 07:57 PM
  #40
NSC5's Avatar
NSC5
Glad that it sounds like it will come out "whole" once you get the new wheel. I am very happy that it has worked out but after the way parts were arranged on your car I would use a different dealership in the future.
Maybe I have spent too many years involved in risk management but it bothers me when careless mistakes and shortcuts are used which greatly increase the probability of collateral damage. I remember when I was still a young kid I read an old electronics magazine which had a regular feature called "Mac's Service Shop" and in that particular episode the bench assistant was observing the shop owner repair one of the "talking book" players which were used by the blind to play books that were available on records. The assistant noted that the owner seemed to be using extra care in re-installing all of the screws and when asked he replied that if you saw how carefully the owner would feel the returned player you would also be extra careful not to put a scratch or gouge in the leather case. The shop owner understood how important that player was to its owner. That is the sort of attitude you would love to find with your tech.
