Someday I will need to do this...but I don't know how!?
The lamp is an electronic fixture, the lamp also has electronics installed in it so the LEDs may last a long time but the electronic drivers can fail easily causing the lamp to fail. Have you ever seen center high mounted stop lamps with failing fluttering LEDs? This is what happens when the electronic drivers fail. This will also require a complete lamp replacement.
