PDR problem, can't find SD card
Old Aug 13, 2015 | 07:32 AM
MJZ's Avatar
MJZ
St. Jude Donor '15
Default PDR problem, can't find SD card
Is there another SD card slot besides the one in the console glove box? I've tried several formatted SD cards but PDR continues to say"no SD card". What am I missing?
Old Aug 13, 2015 | 07:36 AM
Thomasmoto's Avatar
Thomasmoto
It's in the glove compartment, don't use the one in the console for PDR. Its for music.
Old Aug 13, 2015 | 07:51 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
In fact for 2016 there is no SD slot in the console! The only one is in the glove compartment and it is ONLY for the PRD. Since I use SD cards for music was wondering what I would do if I had a 2016? Found this flush mount USD Flash Drive.
Flush mount thumb drive can replace SD card
Old Aug 13, 2015 | 08:29 AM
MJZ's Avatar
MJZ
St. Jude Donor '15
Thanks, I appreciate it.
Old Aug 13, 2015 | 08:35 AM
proeagles's Avatar
proeagles
The slot you need is in the glove box. Also be sure not to lock the card in the adapter if you are not familiar with how it works! That keeps it from being read.
Old Aug 13, 2015 | 09:06 AM
Thomasmoto's Avatar
Thomasmoto
Sorry I didn't know about the 16's. I don't have mine yet.
Old Aug 13, 2015 | 09:37 AM
JerryU's Avatar
JerryU
Saw a post where someone had loaded all his music on two 64GB SD cards waiting for his 2016! He responded to my post and believe he'll just transfer to the Flash Drives.
Old Aug 13, 2015 | 12:50 PM
Black&White's Avatar
Black&White
You need to install the card/drive with the motor running. Try it you'll see! It's a glitch in the software.
Old Aug 13, 2015 | 03:04 PM
Lyons16's Avatar
Lyons16
By chance does the 2016 come with a SD Card?
Old Aug 13, 2015 | 04:49 PM
CorvetteKing_Tony's Avatar
CorvetteKing_Tony
No they removed the SD card for music which they have on all the trucks and SUV's. Why they removed it I will never know. It did not make any sense at all.
Old Aug 13, 2015 | 05:02 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Is that a feature of the 2016's? No such glitch in mine or any of the PDR-equipped cars I used at Spring Mountain.
Old Aug 13, 2015 | 05:04 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
None of the Corvettes come from the factory with an SD card. The '14 and '15 models had an SD slot in the console AND one in the glovebox but the '16 models only come with one slot and it's in the glovebox and can only be used for recording with the PDR.
Old Aug 13, 2015 | 05:11 PM
Lyons16's Avatar
Lyons16
Thanks, I didn't think they did. I'll order one before I get my car.
Old Aug 13, 2015 | 05:44 PM
iclick's Avatar
iclick
Now that's just great. So did they add a USB slot or something to make up for the one-and-only music SD? I guess the bean counters triumphed again, saving the General 50¢ per car for the nixed SD slot. What next.
Old Aug 13, 2015 | 06:02 PM
CaryBob's Avatar
CaryBob
They evidently shorted you an owner's manual. I'd complain if I were you....
Old Aug 13, 2015 | 07:57 PM
Jay_Davis's Avatar
Jay_Davis
I haven't had this problem either. Perhaps it was fixed along the way with one of the software updates.
Old Aug 13, 2015 | 08:45 PM
CaryBob's Avatar
CaryBob
Is that unique to the 2016? Not the case for either of my 2015s.
To PDR problem, can't find SD card
Old Nov 9, 2015 | 07:28 PM
Edwardz's Avatar
Edwardz
After card is in, shut car off and turn back on. The SD card "boots up" when the car starts.
Old Nov 9, 2015 | 11:13 PM
SCB's Avatar
SCB
I think the OP was just confused about the location of the SD Card Slot for the PDR, which is in the lower left corner of the glove box. But even with the SD card in that slot, you will get the "No SD Card" message on the PDR unless the card is formatted (FAT32 or NTFS) *and* if the little read only/write protection lock tab is in the off position (pointed up... toward the top of the card).
Old Nov 10, 2015 | 05:06 PM
Woodson's Avatar
Woodson
3 USB slots not enough?
