Windshield restoration
Old Aug 15, 2015 | 09:03 AM
NoOne's Avatar
NoOne
Default Windshield restoration
I've got just under 17k on my car and the windshield is getting pretty bad.
Not sure if its physical pits or just build up on the glass itself. The only thing ever done to it was powerwashing/regular wash/once a week cleaning its glass cleaner.
I do a lot of highway driving and I'm sure the higher speeds have contributed to it.
Are there any decent restoration products? Not sure if it needs to be polished, filled, or it just has a bunch of tiny dirt particles that regular washing is not getting off similar to the need to clay the paint.
Doing a 6K road trip in 5 weeks and would like to get it cleaned up if thats possible.
Old Aug 15, 2015 | 09:24 AM
nmvettec7's Avatar
nmvettec7
See this thread.....I polished my windshield and applied a nano ceramic glass coating.
https://www.corvetteforum.com/forums...the-glass.html
You need a buffer to complete the work.
Old Aug 15, 2015 | 10:39 AM
stevebz06's Avatar
stevebz06
Have you priced replacement? I had to replace my 98 Camaro windshield, which is huge,
and was surprised at how cheap it was.
Old Aug 15, 2015 | 07:20 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Majority of corvettes released have HUD specific windshields. (2LT, 3LT, Z06) Price one of those and you will rethink your statement of them being cheap
Old Aug 15, 2015 | 07:51 PM
Thunder22's Avatar
Thunder22
In NJ, insurance covers the replacement with a $50 deductable.
In NY, you can get full glass coverage. $0 deductable.
As long as the chip/break is in your line of sight and not fixable.
Old Aug 15, 2015 | 07:54 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
All rock chips are considered fixable. They fill it with a speak clear epoxy so they wouldn't replace it for that.
Old Aug 15, 2015 | 08:41 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
You can try polishing with Bartenders Friend. Less than $10. Worth a try.
Old Aug 15, 2015 | 10:52 PM
Thunder22's Avatar
Thunder22
Originally Posted by FYREANT;1590277547[B
]All rock chips are considered fixable.[/B] They fill it with a speak clear epoxy so they wouldn't replace it for that.
Not true in NY and NJ. Some are bigger than others and not fixable. They will attempt to fix it, but if it obscures the driver's view in any way after the attempted fix, they will replace the windshield.
Old Aug 15, 2015 | 11:12 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
Call a pro to do your windshield! Someone like Safelite. Removing the chips you are talking about will also remove some of the windshield. Using mild abrasives with a polisher is risky at best.
I polish rock and glass for a living and working on a curved surface requires practice and patience. I use fine grits such as 800 grit silicon carbide and diamond and work up to 1200 grit and then to polishes such as Cerium Oxide and 3,000 grit diamond then to get it perfect it goes to 8,000, 14,000 and finish with 50,000 grits. These are all diamond and are mixed in a carrying agent such as Old Miser Grit Carrier ( not referring to any members).
This is very messy and would require masking off the car to protect the paint and other parts as the powders will get into every thing around.
So, call a pro and see what they suggest, filling and polishing may be the best bet. It would certainly be the easiest and fastest way. My way may be a bit over kill for a windshield but it works great for telescope lenses, mirrors and glass counter tops.
Good luck
Old Aug 15, 2015 | 11:36 PM
NoOne's Avatar
NoOne
Sounds like a plan, what pad did you use?
I have Griots dual action buffer, think I have clean white and blue pads.
To Windshield restoration
