Automatic Trunk Closer
With the Coupe many reports of paint cracking because of folks pushing to latch! One report of the composite hatch frame actually cracking for the same reason! I watched my frame bend when I tried pushing to latch when I first got my car and stopped! With the Coupe, a GM recommendation is to push to latch with 2 hands at the sides of the Coupe window where there are peaks. That was no doubt at least one reason GM went back to the motorized pull down for the 2016's (and like my '08 C6,) IMO.
A person wanting to retrofit and one convinced "his dealer" could do it found the opposite. It's more than adding the motor and parts, the electronics (which one person investigated in depth) needs to change and there is no easy way to wire or get the computer software in a 2014/2015 to control what needs to happen at the right time! It's not simply limit switch activated.
Be interesting to see what you find for the Vert but GM has said for the Coupe, "No way to retrofit!" The person who was going to force them to do it on warranty, I think traded it for a 2016! Not really a big deal for me and most, just have to remember to close the hatch before the door! Mine then latches with one finger pushing the latch from full height with one finger while I stand behind the open door!
Curious if yours latches with a door open. If not could well be a mechanical issue. I've tried stop adjustments in my Coupe, loosening the latch screws and closing to align the parts per a GM bulletin and checking to see my vent operate, etc- no help!
When looking at how the memory wire activated vent is operated from the 2014 Service Manual, found it was a voltage spike signal to the computer. Guess that is less expensive than sensing current. Today the computer monitors and controls many function that in years past limit switches etc were used. Perhaps the Vert is different than what one poster spent time with 2015/2016 wiring diagrams defining what was needed for the Coupe.
I’m just an old Hot Rodder but did wire my street rod from scratch, made many wire diagrams, etc with digital dash, electric doors and windows, alarms including one that functions if you forget to set the locking pins for the suicide doors, rev limiter for the ZZ502, full stereo, CD player, amps etc. Worked 1st time and still functioning after 14 years! However although I have been using PC’s since they first came out and did programming of those-(no choice in the ‘70s) it’s not like going into the GM software! Will be very interested in what you find. Wish you luck, many folks would like that retrofit option.
Still wonder why a Vert is having the issue as thought it was only a factor with Coupes.
PS: Many posters removing the bumper for various reasons, no painting will be required! After the bolts it's like many panel removals, clips hold it on. Should be able to search the Forum and get advice or believe I have seen some YouTubes showing what needs to be done.
I’m just an old Hot Rodder but did wire my street rod from scratch, made many wire diagrams, etc with digital dash, electric doors and windows, alarms including one that functions if you forget to set the locking pins for the suicide doors, full stereo, CD player, amps etc. Worked 1st time and still functioning after 14 years! However although I have been using PC’s since they first came out and did programming of those-(no choice in the ‘70s) it’s not like going into the GM software! Will be very interested in what you find. Wish you luck, many folks would like that retrofit option.
Did you say in your 2014 service manual the heated element wire for the air door is controlled by the Module? In mine it shows it being controlled on the same circuit as the trunk lights. Basically when the trunk lights come on so does the wire that controls the door flap. It heats up, expands, and opens the flap. Interesting that the two manuals are different. What manual number do you have?
I hope I didn't come off as having a "know it all" attitude and I sure don't want to belittle anyone because that's not me. I'm learning new things everyday and I love to share what I learn.
Hope that helps. This "old timer" will stick with copper wires and switches and is why I preferred to install an "850 double pumper" on my ZZ502 and change pump volumes, pump cams and jet size to messing with fuel injection! Did use an air fuel ratio meter and oxygen sensor in the exhaust to fine tune!
https://www.corvetteforum.com/forums...-retrofit.html
I'd be happy to email you the schematics for the 15 and 16 which I have. Read that thread and perhaps there is a way to make it work with some relays. But on the 14 & 15's GM changed the role of how the latch interfaces to the BCM. I am sure it can be done with the right EE know how, but it seemed beyond my skill level once I looked into it. So the main difference is that on the early years it was just a striaght signal that the trunk was ajar but on the 16 the BCM is involved. Thus there is a control module, which also controls the motor to pull the hatch down. I would have ordered the latch part but my fabrication skills are poor and it seemed from the pictures that the mount was different between the 15 and 16 too.
It can be done if you got the skill, so if you can figure it out, us armatures would sure like to follow in your foot steps.
