LED lights keep falling down
Old Aug 20, 2015 | 03:17 PM
05XLRtoC7_San Diego's Avatar
05XLRtoC7_San Diego
Default LED lights keep falling down
I purchased the C7 Corvette LED Ambient Footwell Lighting Kit (C7-EXH-1-B) from Southern Car Parts.
The lighting is a HUGE upgrade. Didn't realize how dim just the 1 stock bulb was in each footwell. The white color has a very sophisticated slight blue tint, and looks very futuristic. It does show all dirt on your floormats though!
As much as I like this lighting, I am having difficulties with the LED light strip falling down.
I carefully prepped the area using the alcohol pads.
The adhesive tape it came with was not strong enough to secure it in place.
I also tried using thicker (1") double-side tape, and that only worked for a few days- it's dangling down again.
I'm a bit concerned of the cord and LED light strip falling down while driving and getting tangled with the accelerator or brake.
Has anyone else run into this problem? There's no place to zip-tie the light in. Maybe super glue or some sort of epoxy?
Old Aug 20, 2015 | 03:27 PM
tcotta411's Avatar
tcotta411
Upon initial installation, I reinforced with regular ole' scotch tape.
Never had an issue with them falling and I've done this mod on 4 personal vehicles and on other Corvettes in my car club.
Get some scotch tape and stick at the ends and a few more times in between.
Old Aug 20, 2015 | 03:36 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Get some 3m automotive tape like they use for exterior trim parts. That might work.
Old Aug 20, 2015 | 04:24 PM
05XLRtoC7_San Diego
thanks guys!
I'll try both
and if all else fails- duct tape!!
Old Aug 20, 2015 | 05:14 PM
craig04c5's Avatar
craig04c5
Yep 3M Auto Trim tape will hold it. Press and hold for 30 seconds.
http://www.amazon.com/3M-03614-Scotc...auto+trim+tape
Old Aug 20, 2015 | 07:33 PM
bbrown450's Avatar
bbrown450
also called VHB by 3m Staples sells it by the rool. Remember you have to prep the area with alcohol or activator....best of luck
Old Aug 20, 2015 | 08:00 PM
mrclean1's Avatar
mrclean1
I had the same problem, solved it by just using a tad of household GOOP. Has not come loose since.
To LED lights keep falling down
