There is a device you can plug into the ODB port that disables AFM mode, but it will apparently drain the battery if left in for a long time while the car is not used. A Google search turned up "Range AFM Disable."
On my M7 on the center touch screen settings you can set the NPP exhaust to be always open.
</p><p>Still, the NPP exhaust valves will close under certain RPM/load conditions. The same settings exist on the A6/A8, but AFM works differently on the automatics (it is much more intrusive). On a manual, AFM only works in ECO mode. On the automatics, it works in all modes. Only manual mode sifting on the automatics will disable AFM on a stock vehicle.</p><p> </p><p>Beside the Range disabler device, it can also be eliminated with a tune.</p><p> </p>
Originally Posted by F4 Phantom
Just leave it in Sport or Track mode.
Originally Posted by scottiekay
Pull Fuse 41 or 42 its labeled exhaust.... leaves the valve open
The AFM valves are not the same as the NPP valves. None of the above will change what the OP is experiencing.
And even the NPP valves aren't always open, no matter what you set in the touch screen. Pulling the fuse will keep the NPP valves open all the time, but not the AFM valves,
