ECO mode really does make a difference
Old Aug 27, 2015 | 09:21 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
I'll have to try giving the car hell in eco and winter modes. Not sure if I've ever tried. I switch to sport or track if I'm gonna get on it.
MPG wise In the rolling hills of Iowa, the eco mode is good for about 2MPG better average. I'd say tennis freak is prolly right about the up 2-5MPG comment. You might see 5MPG on a super flat road where 4cyl stays active. In Iowa it's on about 1/2 the time as the "hills" are just enough to force it back to 8cyl mode.
Honestly I think 4 cyl mode could be programmed a tiny bit more aggressively. If you watch the instant MPG though, there is a point where an increased load in 4cyl mode isn't really more efficient that 8 cyl. Once it gets down below 27 MPG in 4 cyl mode is where it switches and the instant MPG upon going into in 8cyl doesn't really change.
Old Aug 27, 2015 | 10:02 AM
DeStreGa5's Avatar
DeStreGa5
I agree. I would have liked to seen cylinder deactivation exclusively locked into Eco mode where it would use V4 mode more aggressively. I'm not sure about the long term effects on the engine using it more often, but I think more people would be using Eco mode if it was more noticeable in the mpg.
Old Aug 27, 2015 | 10:16 AM
James Bertuca's Avatar
James Bertuca
Didn't the Cadillac have that a while back 4-6-8cyl engine ?
Old Aug 27, 2015 | 10:24 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
In my local Corvette club I hear other C7 owners wondering if it's safe to use the AFM. I say if the engine is stock, then worst case you get a new engine under warranty. I use it as much as I can on the highway. My theory is maybe regular use might be a good thing to exercise/lube the AFM components, or at least a neutral thing where AFM related failures can happen regardless of use. My brother has had AFM tuned out of his 2009 Pontiac G8 GT within the first couple months of owning the car yet he still had lifter issues.
Old Aug 27, 2015 | 10:53 AM
Boucherman's Avatar
Boucherman
Default OK, sort of.
Originally Posted by Boucherman
I'll give it a try ,later.
I just got back from a ride. In ECO mode in third gear at 50 mph, floor it and the car is FAST! Same 50 in third gear and in Sport just a small bit faster. Barley noticable to me.
Old Aug 27, 2015 | 11:11 AM
BigJoe's Avatar
BigJoe
It appears I was mistaken. I got the same opportunity this morning on the same ramp and it went like a scalded dog. Maybe yesterday I wasn't WOT for some reason. In any event I'm happier now to be in ECO knowing the power really is there when you need it. (Jury is still out on whether ECO saves gas, though. More on that later...)
Old Aug 27, 2015 | 11:21 AM
RonnieC6Z's Avatar
RonnieC6Z
Looking at the mode chart above brings up a question. If the engine is turned off when the car is in sport mode, will it stay in sport when the car is next started, or does sport have to be driver activated every time the car is started? (I have a Z51 M7 on order)
tunaman's Avatar
tunaman
OP is correct, at least from my experience with our '14 A6. First and only time I found out was at the end of our 4000+ mile trip back home, and a couple of hot rodders tried to goad me into showing them how it performed.
Once we got to a safe and clear section of freeway I hit it (running in Eco mode) and it accelerated like a family sedan. It didn't pull anywhere near as hard as it had in Sport or Track mode.
You're not imagining things.
Old Aug 27, 2015 | 11:26 AM
BigJoe's Avatar
BigJoe
All modes except Track keep the setting between starts. Track reverts to Touring each time.
Old Aug 27, 2015 | 01:20 PM
iclick's Avatar
iclick
Originally Posted by TennisFreak
ECO mode will make about 2-5 mpg difference when cruising on the highway at stable speeds.
I haven't found this to be the case at all in my A8 car, and I see no functional difference between Eco and Sport except for shift behavior, which is quicker in Sport mode as I would expect. It also hangs up around 3-4k RPM for a few seconds longer after I punch it in Sport mode, but goes back down to a normal cruising range in Eco mode much more quickly. I've been keeping mine in Sport for the past month or more and mileage is not down, either on average or observations of instant readings, nor do I see any changes in the behavior of AFM. V4 mode enables with the same frequency, as far as I can tell. I haven't paid much attention to throttle response in different driving modes.
Old Aug 27, 2015 | 02:03 PM
RonnieC6Z's Avatar
RonnieC6Z
Thanks for the info. Since the car will be my daily driver and never tracked, I plan to only use sport mode. Incidentally, a buddy who returned from a 2 day session at Spring Mountain was told by the head instructor never to use track mode on the street because the suspension in track mode is so stiff that hitting a pothole can cause tire and/or wheel damage.
Old Aug 27, 2015 | 02:56 PM
TennisFreak's Avatar
TennisFreak
The reason you have not noticed is because you have an A8.
Cylinder deactivation happens in all modes (except track) for you.
In the M7 cylinder deactivation only happens in ECO mode.
That makes the difference in MPG for me.
Old Aug 27, 2015 | 03:29 PM
  #33
DickieDoo's Avatar
DickieDoo
Does the mode affect the M7 1 to 4 skipshift ? I ordered a 2016 Z51 M7
and see that the Skip Shifter disable resistor is still being sold for the C7 but my guess is that if your in anything better than tour, it should not try to glide you to 4th
Old Aug 27, 2015 | 03:32 PM
  #34
iclick's Avatar
iclick
The reason you have not noticed is because you have an A8. Cylinder deactivation happens in all modes (except track) for you. In the M7 cylinder deactivation only happens in ECO mode. That makes the difference in MPG for me.
All true and undoubtedly the difference between A8 and M7. I was actually expecting to see some difference in the frequency of AFM behavior, like more V4 mode in Eco, etc.--but I haven't seen that either. I was going by the chart, which suggests that Eco has its own AFM mode with all the others showing as "normal," but maybe that's only for the M7.
Old Aug 27, 2015 | 03:43 PM
  #35
Rave's Avatar
Rave
Easy to see the difference. When traveling on level ground, monitor instantaneous MPG readings, hold a steady speed, and switch between Eco and other modes. Mine shows about 2-3 mpg better in Eco mode.
Old Aug 27, 2015 | 06:23 PM
  #36
kevincol's Avatar
kevincol
Originally Posted by CaryBob
In my M7 I don't think there is any throttle difference between Eco and Tour.
Old Aug 27, 2015 | 07:03 PM
  #37
z edge's Avatar
z edge
Interesting stuff there.
I have only used track mode once or twice just to play around. Never really got full throttle yet for whatever reason though. I would hate to hit a pothole in any mode though but especially with the stiffened suspension. I usually just drive in Sport mode and feel fine doing so.
To ECO mode really does make a difference
Old Aug 27, 2015 | 07:58 PM
  #38
Richard Ames's Avatar
Richard Ames
Weather also reverts to Touring upon restart least my a8 does.
Old Aug 27, 2015 | 08:27 PM
  #39
CaryBob's Avatar
CaryBob
Be thankful you don't have a European model of the C7. They all default to Eco Mode at startup.
Old Aug 27, 2015 | 09:52 PM
  #40
meyerweb's Avatar
meyerweb
Skip shift is active in all modes, but it seems to be less aggressive in Sport than Tour, and less aggressive still in Track. This isn't documented anywhere that I've found, but when I installed the skip shift eliminator I had to go into tour mode to get the warning message to come on with any frequency. But it will show up, sometimes, even in Track mode.
