Any ideas about temporarily attaching plate to NoviStretch bra?
Anybody got any ideas?
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I put the bra over my front plate. Haven't been stopped yet.
I use the aero plate. Glued N52 magnets behind the aero plate at the 4 corners, and another 4 small ones on the plate corners itself. super easy to pull the plate off, put bra on, and put the plate back up. I was worried perhaps it wouldn't hold, but 2000 miles at up to 100 and no problems.
Where do you get Aero plate from?
I use the Sto-n-sho license plate mount. It mounts low enough that you can remove the plate (a simple, 10 second job), install the Novistretch, then reattach the plate (another 10-20 seconds).
(This is a Mustang, but it works the same on a 'vette.)
Forum vendor RPI sells it. Others may also.
http://www.rpidesigns.com/shop/item.aspx?itemid=3330
Received 1,694 Likes
St. Jude Donor '15
That's a GM part. Kind of expensive though for what you're doing. I'd think any cheap-o metal frame would work.
http://www.gmpartsdirect.com/results...umber=22979545
The Aero plate is standard, should have been in the car. The expensive ($160) version is painted with carbon flash. The OEM looks fine without paint.
Anybody know if sto n sho works with poverty splitter!
