Hood
Old Aug 30, 2015 | 03:50 PM
James Bertuca's Avatar
James Bertuca
Default Hood
How firm do you have to close the hood, having a tough time with the left side of hood, I have my hand in the center of the hood when closing, right side is fine, left side catches but not 100%
Old Aug 30, 2015 | 04:18 PM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
You should close it firmly with pressure on the top (closest to the windshield) center of the hood. The hood is carbon fiber and it doesn't weigh that much. That's why reasonably firm pressure is required for both sides to latch properly. But again, the pressure should be exerted in the center of the hood, not on one side or the other.
Old Aug 30, 2015 | 04:23 PM
Glen e's Avatar
Glen e
Like they show you at the museum, i drop mine from a foot, never fails.
Old Aug 30, 2015 | 04:33 PM
dvilin's Avatar
dvilin
Old Aug 30, 2015 | 05:05 PM
mcginna's Avatar
mcginna
Default Hood
I drop mine from about a foot up, always closes.
Old Aug 30, 2015 | 05:45 PM
bigfainer's Avatar
bigfainer
Default Hood
Does the DIC alert you if the hood is not closed completely?
Old Aug 30, 2015 | 07:27 PM
FLS2K's Avatar
FLS2K
^^^this
Old Aug 30, 2015 | 11:48 PM
proeagles's Avatar
proeagles
Old Aug 31, 2015 | 08:52 AM
rcooper's Avatar
rcooper
St. Jude Donor '15
I have to drop mine with a bit of a push from about 18" for it to latch on both sides. As many have said dropping from a foot is good, but won't work in my case, left side seems to be hit and miss. After playing around with it found that the 18" with a little push and it works fine.
Old Aug 31, 2015 | 09:00 AM
Red C8 of Jax's Avatar
Red C8 of Jax
Like mentioned, the key is to push down from the center of the hood.
Old Aug 31, 2015 | 09:01 AM
sanantguy's Avatar
sanantguy
drop it from 18 inches or so. closes every time.
Old Aug 31, 2015 | 09:48 AM
C8-Vette's Avatar
C8-Vette
On the side that does not close ,turn the black adjuster 1 or 2 turns clockwise. You still have to give it a good wack.
Old Aug 31, 2015 | 11:03 AM
sonnie's Avatar
sonnie
Default Hood
Went to the Corvette plant last month and saw them closing the hood by standing in front of the car, and using a clean cloth pushing the hood down from the center of the hood... All closed cleanly every time.
Old Aug 31, 2015 | 12:08 PM
James Bertuca
Thank you for all reply's
Seems a little loud, but it works 18" with a firm push, I guess I'm afraid since you hear so much about everything is made of plastic
I'm a little gun shy of the (firm & push ).
Jim
Old Aug 31, 2015 | 01:16 PM
C8-Vette's Avatar
C8-Vette
Jim
Its carbon fiber, At Grumman some of our fighter wings were the same material!
Old Aug 31, 2015 | 01:17 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Jim
The "plastic" is fiberglass reinforced. Premix who supplies SMC and was a pioneer in the field says it's typically ~25% with about 40% filler and the remainder resin. But the hood is carbon fiber, thinner and lighter but should be plenty strong.
Funny in my C6 I had to close from the Drivers side to get both to close 100% of the time. With the C7 unless I close from the Passenger side I get both closing only 75% of the time! If I close from that side it's 100%.
I'm not under the hood that often, so no big deal. Guess I could try to close from the center or make an adjustment but why bother.
Old Aug 31, 2015 | 02:28 PM
sonnie's Avatar
sonnie
Originally Posted by JerryU
The "plastic" is fiberglass reinforced. Premix who supplies SMC and was a pioneer in the field says ~25% with about 40% filler and the remainder resin. But the hood is carbon fiber, thinner and lighter but should be plenty strong.
Funny in my C6 I had to close from the Drivers side to get both to close 100% of the time. With the C7 unless I close from the Passenger side get both closing only 75% of the time! If iI close from there it's 100%.
I'm not under the hood that often, so no big deal. Guess I could try to close from the center ok make an adjustment but why bother.
When trying to close the hood from either side my 15 z-51 it would close on the left front, but not the right facing the hood, no matter which side I dropped the hood on from about 14 or 15 inches.. Soon as I started pushing the hood shut from the front of the car midway up the hood, it shuts perfectly on both sides... and as mentioned earlier, the hood is carbon fiber, it its pretty tough, and doesn't crack easily.
To Hood
