Clay Bar?
Old Sep 8, 2015 | 12:35 AM
Maxie2U's Avatar
Maxie2U
Default Clay Bar?
Like to know if you clay bar your C7.
Yes or no. If no, why not.
Old Sep 8, 2015 | 12:47 AM
owc6's Avatar
owc6
Yes.
If you've never clayed a car before, you'd be amazed at what it removes, and how smooth it feels. The perfect prep for polishing/sealing/waxing.
And I like clay better than nano skin. Others like nano.
Old Sep 8, 2015 | 03:09 AM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
Yes, each year to remove surface imperfections before polishing, waxing, etc.
Old Sep 8, 2015 | 06:30 AM
vettpapaw's Avatar
vettpapaw
Originally Posted by owc6
Yes.
Old Sep 8, 2015 | 07:05 AM
C7Joy's Avatar
C7Joy
Yes, always prior to sealing or waxing.
Old Sep 8, 2015 | 08:45 AM
C7cmnthru's Avatar
C7cmnthru
Once a year at most to remove surface contaminants. Sometimes I just do the horizontal surfaces as that is where the greatest likelihood of surface contamination sits, IMO. I probably have a view on clay bars that is different from most. And that is, I try to minimize its use because clay bars are abrasive. My Vette is parked in a garage which minimizes surface contaminants. While clay bars are a good "tool" I personally think they are over-sold and over-used. A high quality polish/cleaner is less abrasive when surface contamination is really not an issue.
Old Sep 8, 2015 | 08:58 AM
dvilin's Avatar
dvilin
No, I understand the purpose of Clay Bar but have never used it. I find a good wash, polish and wax does it for me. Surface looks good, nice shine sometimes good is good enough.
In the past with my C6 I used Rejex this time around with my C7 I tried the updated Liquid Glass and the results are quite impressive.
Again not discounting the proper prep of the paint surface with Clay Bar just think it is slightly over rated.
Old Sep 8, 2015 | 10:11 AM
dbdave's Avatar
dbdave
Yes, on all my vehicles, but only when needed maybe once a year.
Old Sep 8, 2015 | 10:16 AM
GizmoZ's Avatar
GizmoZ
I always clay first. What's the point of going through the trouble of waxing if you don't prep the surface properly first? Wax isn't going to stick to sap, particles, etc. stuck in your clear coat. It might take 30 extra minutes, but it's worth it to me to know the job was done right.
Old Sep 8, 2015 | 10:23 AM
Glen e's Avatar
Glen e
agreed...why seal crap in? always clay before starting a major detail - like once a year....it gets stuff the polish does not
http://www.autogeek.net/detailing-clay-bar.html
Old Sep 8, 2015 | 11:05 AM
nmvettec7's Avatar
nmvettec7
Clay barred my C7 right after delivery with only 50 miles.
You don't know how good a clay bar is until you use it.
There is a simple test to see if you need the car clay barred.
Feel the surface of the paint with your hand and fingers. It might feel nice and smooth.
Then get a sandwich baggie (not a heavy duty freezer bag) and put your hand in the thin plastic sandwich baggie, then run your fingers over the paint surface with your fingers inside the baggie.
If the paint surface feels like sandpaper, or gritty, this test will immediately tell you the paint surface is contaminated. The only to remove the hidden grit embedded into the paint surface is to clay bar or nano skin the paint surface.
Like "Glen e" says above, why apply any paint coating, wax, or even products like liquid glass over dirty embedded paint that you can't see.
If you get the grit feel, it is time to start from scratch and clay bar or nano skin then apply your paint sealant, coating, wax, liquid glass or what ever you choose.
Try this simple test that only takes a minute. You might be surprised what you feel.
Old Sep 8, 2015 | 11:35 AM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
to all my rides
Old Sep 8, 2015 | 12:17 PM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
Yes, once a year and always before applying any sealant or wax.
Old Sep 8, 2015 | 12:32 PM
VETJAZZ's Avatar
VETJAZZ
Old Sep 8, 2015 | 12:43 PM
kevincol's Avatar
kevincol
I always have always used clay, but started seeing more and more on the form about nanoskin. I checked it out over the weekend and realized that I was spending too much time with clay bars and ordered a bunch of nanoskin products with the AutoGeek.NET 20% off Labor Day sale. While I had my wife's Abarth and my C7 professionally applied with Opti-Coat Pro Plus, I still have two other cars that I was going to do my self. I'm hoping that the nanoskin with an orbital will had a signficiant reduction of time for me on prepping the cars before putting on the Black Diamond product that NMVetteC7 is using.
Old Sep 8, 2015 | 02:01 PM
Larry/car's Avatar
Larry/car
No! Looks just great without the fuss.
Old Sep 8, 2015 | 02:06 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Put your hand in a plastic bag and lightly run it across the car...if it grabs you need to clay it....A good wash, polish and wax will not remove what the clay bar will. If you just wax or polish all you are doing is sealing the DIRT into the clear coast....just trying to make your beautiful white Vert shine even more....in the dull Rochester Sky.....
To Clay Bar?
Old Sep 8, 2015 | 02:13 PM
scottsh's Avatar
scottsh
Just FYI - I hear the pro detailers have moved to a clay towel or other solution that is easier to handle than clay bar nowadays (if you drop the clay on the ground you have to toss it, a clay towel can be washed) - might be worth pricing those vs clay.
Old Sep 8, 2015 | 02:17 PM
drs's Avatar
drs
Yes, before the first detail and wax applied.
Old Sep 8, 2015 | 02:32 PM
yellowgrandsport's Avatar
yellowgrandsport
I disagree with the clay bar system. Today's paint is mostly water born base and clear. The water clear is softer than clears from the past. If your not careful you damage the surface.
After clay baring your car take a flash light an shine the light from the bottom up on each panel n look for scratches left by the clay bar. If you feel you must clay bar because that's what you knew from years past make sure you keep the bar wet as possible. I would have a spay bottle of a good wash n wax product n spay the surface not the bar offen.
When done use the flash light or move the car into the sun. Open the hood so the sun shines directly on the hood n look for small scratches.
I fine finding a good car car product ( not a paste or liquid wax) like Croftgate car care products will do your job faster n easier and leave a smooth clean surface.
