Dent on center console trim
The other day, I was using my iPhone 6+ w/o a case in the car, slipped out of my hand a put a tiny ping on the aluminum by the drive mode selector and cup holder... Has anyone had this happen? How hard was it to remove the panel to replace/repair? It is so tiny that I don't know I'd take it apart to repair!
that ding will drive ya
Remove the three torx screws on the console lid. Pull off the horizontal trim piece on the drivers side. Start prying the console off from the rear with your fingers. When the rear clips are off and the console is still attached in the front, pull backwards and the console will be in your hand.
Received 19,300 Likes
'20-'21-'22-'23-'24
Good luck getting it fixed. Even though someone else may never notice the ding, it still has a tendency to bother you since you know it is there.
