Eco Mode
Old Sep 18, 2015 | 01:38 PM
ref772's Avatar
ref772
Default Eco Mode
I've tried to use 'search' for this question but couldn't find the answer. So, if its an old subject, please forgive me. When the V4 mode comes on, how are the cylinders chosen to deactivate? I assume it is not random since that could result in an uneven firing order. If it is the same 4 cyls. each time, that would result in uneven wear and ring groove issues. Once the V4 mode activates, do the same 4 cylinders stay deactivated until the next occurance of V4 mode or do they switch around from one group of 4 to another group of 4?
Old Sep 18, 2015 | 01:50 PM
BOBSZ06's Avatar
BOBSZ06
Same 4 cylinders; they all move and wear (only 4 fire), so no wear issues.
Always the same cylinders.
Old Sep 18, 2015 | 01:59 PM
Jim Barker's Avatar
Jim Barker
[QUOTE=ref772;1590520450]I've tried to use 'search' for this question
It also has a duty cycle of 10 min on and 1 min off. and has settings that are a lot more aggressive on automatics than stick shift cars. Factory did tweek the TPS Max from 50% on 14's to 40% on 15's. Per tables from HP Tuners.
Old Sep 18, 2015 | 02:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
<p></p><p>&nbsp;</p><p>Active Fuel Management (AFM), which shuts down the LT1&rsquo;s firing cylinders from eight to four by disabling the valves to the cylinders, also brings the efficiency of the 6.2L pushrod motor to never-before-seen heights. When AFM commences, the engine turns the 6.2L V8 into a 3.1L V4, shutting down cylinders 1, 4, 6 and 7, and firing only cylinders 8, 2, 5 and 3 in that order. Otherwise, the complete firing order is 1, 8, 7, 2, 6, 5, 4, 3.</p>
Old Sep 18, 2015 | 02:07 PM
Jim Barker's Avatar
Jim Barker
The system is allowed to engage in 3rd gear and up on the auto and 4th for the stick when eco is selected. All modes for the auto except manual paddle shift. It goes back to V8 quicker when TPS max percentage is lowered.
Old Sep 18, 2015 | 02:13 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I've tried a couple times to measure the difference in mileage when running in Eco, Tour and Sport modes. Used the same stretch of highway for each run but the temps were slightly different. Car was loaded the same and speeds were the same. Very little difference in mileage. What exactly does Eco mode do? Is it supposed to increase the amount of time spent running in V4 mode?
Old Sep 18, 2015 | 02:18 PM
Curahee's Avatar
Curahee
Don't use ECO mode. It's bad for the motor.
Old Sep 18, 2015 | 02:22 PM
Rguy271's Avatar
Rguy271
ECO is the only mode where the engine will go into v4 mode. It's supposed to help save on gas, and in theory it should since only half the cylinders are active.
IN reality, most people arent seeing very much, if any difference in MPG.
Old Sep 18, 2015 | 02:30 PM
Jim Barker's Avatar
Jim Barker
At a recent Cars and Coffee looked at a Audi RS-7 and it also has DOD and external mechanical fuel pumps that were amazingly quiet one on each bank.
Old Sep 18, 2015 | 02:31 PM
ESBloefeld's Avatar
ESBloefeld
Is Eco the only mode that allows 4 cylinder operation? The reason I ask is that I'm thinking that I never want the engine to run on 4 cylinders. I know that GM had to beef-up the drive train of the C7 to deal with vibrations induced by 4 cylinder operation. I'm not sure I really want to stress the drive train if I can avoid it. Is this concern silly of me?
Old Sep 18, 2015 | 02:36 PM
CaryBob's Avatar
CaryBob
That is only true of the manual transmission. With an automatic transmission, it can go into V4 in any driving mode except Track.
Old Sep 18, 2015 | 02:37 PM
sanantguy's Avatar
sanantguy
That is not correct. evidently you don't own this car in auto
And when in eco mode, it is very obvious that the car goes into V4 mode more often than when in tour, or sport.
Old Sep 18, 2015 | 02:38 PM
Rguy271's Avatar
Rguy271
Ah ha, didnt know that. That would **** me off honestly, can you just disable it in those modes?
Old Sep 18, 2015 | 02:44 PM
Jim Barker's Avatar
Jim Barker
On my '14 track mode DOD is also allowed. If you have a later model and it does not then they are doing more tweaking!
Old Sep 18, 2015 | 02:54 PM
Jim Barker's Avatar
Jim Barker
Shift selector in Manual and then paddle shift only way GM lets you do it!
Old Sep 18, 2015 | 04:50 PM
iclick's Avatar
iclick
Here are a couple of write-ups on this subject:
Write-up 1
Write-up 2
My A8 goes into V4 in any mode, even Track. The Driving Mode chart in the manual backs this up.
Originally Posted by sanantguy
That is not correct. evidently you don't own this car in auto. And when in eco mode, it is very obvious that the car goes into V4 mode more often than when in tour, or sport.
I agree with you that mileage is noticeably better in V4 mode, close to the 2-3mpg claim made by GM in my car, but I haven't seen any difference at all on AFM operation in Eco, Tour, or Sport. My mileage has been as good in Sport (my choice for the past two months) as it was in Eco, where I had it set most of the time before that. Mine's an A8, BTW.
OTOH, the manual states that Weather, Tour, Sport, and Track all use "Normal" AFM operation, but Eco uses "Eco," so there must be an AFM difference in Eco driving mode compared to the others.
Old Sep 18, 2015 | 05:52 PM
HoustonMidtown's Avatar
HoustonMidtown
I don't understand the hate for AFM - it is only in V4 mode when there is little or no load on the engine, as soon as you need more power it instantly goes back to V8...anything that helps me visit a gas station a little less is fine with me.
To Eco Mode
Old Sep 18, 2015 | 05:59 PM
meyerweb's Avatar
meyerweb
And you have evidence to support this? Or just your assumption?
Old Sep 18, 2015 | 06:12 PM
rogergcam's Avatar
rogergcam
Default Why?
WHY?
Old Sep 18, 2015 | 06:13 PM
fdxpilot's Avatar
fdxpilot
Well, everyone's entitled to an opinion. OTH, I've been driving an Avalanche with AFM for 9 years with no problems. The two C7s have 17k and 4k. Both autos, so they go into V4 mode regularly, although the Z does so lots less than the Stingray. No engine problems on either of them.
