Seat Extension Thread?
Old Sep 22, 2015 | 10:21 PM
TulsaVette's Avatar
TulsaVette
Default Seat Extension Thread?
I tried search but had no luck.
Wasn't there a thread about a plug under the drivers seat that could be unplugged to allow for the seat to go back a little further?
Thanks in advance if you can point me to it.
Ordered a 2LZ Z06 today, 6-8 weeks and so it begins.
Old Sep 23, 2015 | 08:08 AM
Casey VP26's Avatar
Casey VP26
Yes there was a thread. If I remember correctly it was about removing the stop bolt or screw and you were able to leave it out. Hope you find it
Old Sep 23, 2015 | 08:40 AM
meyerweb's Avatar
meyerweb
As far as a connector, I think what you're referring to is the limit switch, which is under the carpet behind (not under) the seat.
Old Sep 23, 2015 | 08:48 AM
Casey VP26's Avatar
Casey VP26
OK, Try this. Thread Date 07/05/15, Title: "C7 Corvette, I'm to tall for it " Read thread, then follow link at post #41 which is a few years old. You were correct it is a plug and not a bolt or screw as I thought. I believe this is what you are looking for. Good Luck.
Casey
Old Sep 23, 2015 | 09:56 AM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
https://www.corvetteforum.com/forums...at-memory.html #11 is what I added; if you have any issues with yours, just send me a PM and I will work you through the very simple process.
Something else to keep in mind; the limit switch will also effect the EZ exit program if you are on the tall side like myself.
Old Sep 23, 2015 | 09:58 AM
meyerweb's Avatar
meyerweb
Here's the thread the post above is directing you to:
https://www.corvetteforum.com/forums...ce-here-2.html
Old Sep 23, 2015 | 10:42 AM
william43's Avatar
william43
Did mine a week ago. Works Great.
Old Sep 24, 2015 | 09:54 PM
TulsaVette's Avatar
TulsaVette
https://cimg2.ibsrv.net/gimg/www.cor...19a3a04bb2.jpg
Is it the two wires near the top or the connector on the left?
Old Sep 25, 2015 | 10:48 AM
william43's Avatar
william43
connector on the left. That's were mine was.
To Seat Extension Thread?
