RPI Designs APR C7 Z06 Real Carbon Fiber body components
Platinum Supporting Vendor
C7 Z06 APR Real Carbon Fiber Body Components
C7 Corvette Z06 APR Carbon Fiber Track Pack Front Airdam Splitter
Our C7 Corvette Z06 real carbon fiber track pack front splitter is the ultimate for your C7 Z06. This front splitter is made of 100% carbon fiber, is extremely strong and very lightweight. If you are serious about your C7 Z06, this splitter is for you. Not only does it look great, but functions better than any other performance splitter on the market.
Item # FA-207028 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5451
C7 Corvette Z06 APR Carbon Fiber Side Rockers Skirts
If you are looking for the best quality carbon fiber to put on your new Stingray Z06 then look no further than this APR C7 Corvette Stingray side rocker extensions kit. Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the under- body. Or course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item # FS-207028 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5214
C7 Corvette Z06 APR Carbon Fiber Rear Spoiler
If you are looking to give your C7 Corvette Z06 a fresh, bold look, then look no further than our APR Performance real carbon fiber rear spoiler. This spoiler is made of 100% carbon fiber and comes complete with the wickerbill as shown in the photo. UnLike the factory GM wicker bill that is non adjustable, this one can be adjusted 7/8's of an inch. This spoiler is not only designed for great looks, but will also perform as it was intended. This spoiler bolts right up to a C7 Z06 Corvette.
Item # AS-105757 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5447
C7 Z06 Real Carbon Fiber Lower Diffuser
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffusor. Made in the USA by APR.
*Rear diffusers help reduce turbulence of the under-body airflow that exits the rear of the vehicle. This helps to reduce both lift and drag
Item # AB-277019 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4971
C7 Z06 Real Carbon Fiber Side View Mirror Housings- set
These C7 Corvette Stingray Carbon Fiber Mirror Housings are very light weight and replace your existing mirror housings.
This mirror conversion kit replaces the factory mirror housings (but re uses the existing lenses and power mirror mechanisms).
Item # CF-207007 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4970
C7 Corvette Z06 APR Carbon Fiber Front Fender Vents
Give your C7 Corvette Z06 the very best treatment with these replacement carbon fiber front fender vents. These front fender vents are made by APR Performance and designed to simply replace your existing OEM GM plastic vents. Once you get these new Z06 Carbon Fiber vents installed, just transfer your Z06 badges from your old plastic pieces to these new carbon fiber pieces. These C7 Z06 front vendor vents are sold as a pair. Free ground shipping on these vents.
Item # CF-700802 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5449
C7 Corvette Z06 APR Carbon Fiber Hood Vent
Here is a great way to set your C7 Corvette Z06 apart from the crowd. This real carbon fiber hood vent is a direct replacement of the existing plastic hood vent. Simply remove your plastic hood vent and replace with this carbon fiber hood vent. Built to be the exact same shape and size as the OEM GM unit. This hood vent is clear coated for a high gloss, show winning shine.
Item # CF-700805 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5448
C7 Corvette Z06 APR Carbon Fiber Rear Quarter Panel Ducts
These C7 Corvette Z06 carbon fiber rear quarter panel ducts are a great match to our front fender ducts shown to the right side of your screen. These rear quarter panel ducts are made of real carbon fiber by APR Performance and designed to simply replace your existing ducts. Installation is quick and easy. These quarter panel ducts are sold as a set of two.
Item # CF-700804 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5450
__________________
We are getting more and more calls that GM is having time constraints on supplying carbon fiber Front splitters and side skirts to pre production orders. So instead of waiting for GM, here is a win win, you get the same High quality products at a much cheaper price and you can place the order for your new z06 so you can get it for spring time. Give me a call if you have any questions or would like to place an order 888-257-8515 ext 2. Thanks, Don
This is a high-quality carbon fiber splitter!
Attachment 47918231
Attachment 47918232
Attachment 47918231
Attachment 47918232
If you have any question just give us a call at 888.257.8515
Use Coupon Code RPICHRIS5 for an Immediate Discount!!!
These make a great addition to any C7 Corvette!
If you would like to visit our Online Catalog for access to our entire
C7 Corvette Line of Parts and Merchandise Available for Sale,
just click the link below...
Website Link:
RPI Designs’ C7 Corvette Online Catalog
Forum Members,
Use Code
RPISHELLEY5
at Checkout for an Immediate Discount.
This Coupon Code is always Active!
