Coolant Temperature Gauge
Old Sep 25, 2015 | 07:42 PM
DavePowell's Avatar
DavePowell
Default Coolant Temperature Gauge
I've never figured out the calibration of the analog coolant temperature gauge. Obviously the "220" is not even near the corresponding hash mark for that temperature.
On my analog gauge normal operating range is with the needle EXACTLY across the center "2" of the "220". Here's the puzzling thing: The needle position is exactly there when the digital temperature shows anything from 184 to 214 degrees! I've never seen the temp above 214, so I don't know what the actual range of values will display at exactly the same needle position, or if it ever goes above that center "2".
The hash marks indicate 10 degrees or maybe 20 in the upper range, but in any case it shouldn't stay on that one spot for a range of at least 30 degrees!.
In another thread, someone commented that (digital) calibrations are only approximate. Nonsense. I would be surprised if they were off more than two degrees in the range of 212-240 degrees. The engine calibrations depend on accurate coolant temperature.
Dave
Old Sep 25, 2015 | 07:52 PM
millpond's Avatar
millpond
The analog gauge is marked strangely. Use the digital.
Old Sep 25, 2015 | 08:56 PM
Ely's Avatar
Ely
Mine is the same way. Needle is always 20"% higher than the digital. I don't know which one is correct
Old Sep 26, 2015 | 12:32 AM
mpuzach's Avatar
mpuzach
Are you sure you're looking at coolant temperature and not oil temperature?
Old Sep 26, 2015 | 12:37 AM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
In my 15' Z51, the analog gauge is almost identical to the digital reading I get on my MSD DashHawk.
Old Sep 26, 2015 | 02:13 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
M
Dave
Someone mentioned that the gauge markings are laid out by designers to look good, not the engineers. You could make a case that the 220 is really referring to the heavy longer line at the top of the 220 NOT the line that is slightly below that could be 200!
I have a 2014 Z51 and do not have a digital gauge available to display, that I have found!
Old Sep 26, 2015 | 12:12 PM
bluvette2000's Avatar
bluvette2000
Go into tour display mode and find the info display with the car in the center and the digital read outs stacked on the right.
Old Sep 26, 2015 | 03:21 PM
DavePowell's Avatar
DavePowell
Still, the thing that seems really odd is that anywhere between 184 or 214 (and maybe higher) the analog needle stays exactly in the center of the "2".
Dave
Old Sep 26, 2015 | 08:13 PM
owc6's Avatar
owc6
The analog coolant gauge has large tick marks every 20 degrees below 220, and every 10 degrees above that, with larger spacing between ticks, which makes sense (as long as you know what you are looking at), because it's more precise the closer it gets to overheating.
Awhile back there was a thread about the discrepancy between the analog coolant temp and the digital one. It was speculated that since the icons aren't the same (analog=traditional coolant icon, and digital=engine icon), they weren't' actually reading out the same input; perhaps, they were readings from two different places.
My analog reads 220 and doesn't vary unless it's super-hot outside. My digital will vary with engine load; higher engine load=higher readout within seconds. I can watch it vary while accelerating and downshifting. While cruising, the digital will read 10-12 degrees lower than the analog without fail.
Old Sep 27, 2015 | 01:36 AM
Michael A's Avatar
Michael A
The analog coolant temperature gauge is an "idiot gauge" that stays at 220, unless the car overheats. It was designed by the same person who does the Toyota Camry gauges (moonlights at Chevy).
I've heard they got someone to fix this for 2015.
Hopefully, for the C8 they will put in gauges that don't require that you paste a protractor to the dash to figure out what the readings represent.
Michael
Old Sep 27, 2015 | 04:14 AM
JerryU's Avatar
JerryU
Thanks. Never in Tour mode. Had tried in Track and Econo but not Tour. Will do when back in town!
To Coolant Temperature Gauge
