Crazy GPS...
Old Sep 27, 2015 | 06:35 PM
larry knapp's Avatar
larry knapp
Default Crazy GPS...
I have a 2014 Stingray LT3 that I took delivery on January 4 2014. Have traveled to Texas, California, Nevada, Arizona and other points using the GPS. It worked flawlessly.
Just returned from the Route 66 Car Show in Springfield IL. That stupid thing wanted to take me off the obvious routes to my destination, down residential streets and other roads that were obviously not the correct way.
I have not updated the navigation. Is this the way they punish you for not buying the updates????
Old Sep 27, 2015 | 09:19 PM
bob guzzy's Avatar
bob guzzy
Did you change any settings, it might default to the around about route when not updated.
I really can't see owning a built in when hand held units come so cheaply.
Old Sep 27, 2015 | 09:32 PM
CaryBob's Avatar
CaryBob
The way you set the traffic preferences, segment preferences, and route preferences can cause that to happen if the "correct" route was congested, slowed by an accident, or involved some feature that didn't fit with a segment or route preference you had set. If the navigation system worked to your liking in every other instance, but this one time led you through back streets, that's what I'd suspect first.
Old Sep 27, 2015 | 09:38 PM
meyerweb's Avatar
meyerweb
Are there options to avoid toll roads or highways that might have gotten changed and affected the route?
On my Garmin, I once forgot to reset an "avoid highways" preference, and the thing tried to route me off the highway at every exit, and then right back on from at the same interchange. It was doing it's best to get me off the highway.
Old Sep 28, 2015 | 09:53 AM
Zymurgy's Avatar
Zymurgy
Moderator
Beware of the setting "Shortest Route". It may be the shortest route by distance, but it will frequently not make any sense in terms of the most appropriate roads to take.
Old Sep 28, 2015 | 03:58 PM
ratman6161's Avatar
ratman6161
I can't remember exactly what the setting is on the NAV on my 2014 but its now doing exactly the same thing i.e. avoiding highways and sending me down smaller roads. It only started doing it after I messed with the settings so I'm sure I just need to go back and undo whatever it is I changed.
Old Sep 28, 2015 | 04:14 PM
BigJoe's Avatar
BigJoe
I noticed the same thing last weekend. I was on a freeway that was just finished (after the current GPS map update) which changed things like what side of the road off ramps were and the nav didn't handle it well. But, I must say, once I motored on to older roads (ignoring the seemingly frantic messages from the nav) it recalibrated quickly and was back on course.
Old Sep 28, 2015 | 09:27 PM
larry knapp
Default Crazy GPS
Thanks for the help!
Old Sep 28, 2015 | 09:31 PM
Zymurgy's Avatar
Zymurgy
Moderator
Navigation > Routing Preferences > Route Style. Also, Navigation > Routing Preferences > Use Toll Roads (also Use Freeways, Use Carpool Lanes, Avoid Slow Traffic and Use Tunnels) - all can be set to On or Off.
Old Sep 29, 2015 | 08:32 AM
ratman6161's Avatar
ratman6161
Yup, that is an issue inherent with a system that stores its maps locally which would include both built in Nav systems (not just GM) as well as Garmin etc stand alone devices.
A big advantage to a system like Google Maps (or pick your favorite) is that it gets its maps over the internet so you always have the most up to date map available. A big disadvantage of a system like Google Maps is that it gets its maps over the internet so no internet connection = no maps unless you have planned ahead. Of course you can get a Garmin with lifetime map updates. If only GM would do that with its NAV systems
To Crazy GPS...
