Epoxy Garage Floor
Old Oct 5, 2015 | 12:25 PM
Bencher's Avatar
Bencher
Default Epoxy Garage Floor
Planing to paint my concrete garage floor with a black epoxy coating. Anyone have experience with this and if a particular brand is better than another.
Planning to look similar to this.
Old Oct 5, 2015 | 12:54 PM
robert miller's Avatar
robert miller
Default ttt
I got mine from Lowes got the one that was like 120.00 per box. JUST MAKE SURE YOU MIX IT LIKE IT SAY THAT IS ON THE HARDENER.
If you don't mix it correct it will get hard really fast on you. Plus if what you get has a non slip pack of stuff with it use it for sure. If you get that floor wet & don't use it you will end up on your azz really fast.
Old Oct 5, 2015 | 12:58 PM
RobertEarl's Avatar
RobertEarl
Go to GarageJournal.com. There is a lot of good info on floors there.
Reb
Old Oct 5, 2015 | 01:05 PM
C7cmnthru's Avatar
C7cmnthru
The floor in the picture does not look like an out of the box coating. In any case, make sure you prep the floor correctly. There is a difference in "old" concrete vs "new" concrete. In worst case, grinding the surface may get you the best results. Previosly I used "U Coat It" with great success. But it was on a new floor and only required a muriatic acid wash. But it was dangerously slippery when wet. Durability was excellent with zero hot tire lifting.
With this current garage (again "new" concrete), I decided to get a professionally installed coating called polyaspartic. Really like it a lot more than straight epoxy. Not cheap at about $4.25 to $5 a square foot installed. But it is awesome.
Old Oct 5, 2015 | 01:12 PM
Bob-USA's Avatar
Bob-USA
The concrete must be absolutely spotless for any coating to adhere properly. I had a company called Premier Garage Coatings do my three car garage 5 years ago and it is just like they did it yesterday. They use a floor grinder / sander in order to get the concrete like snow white before they begin the special glue process and then spread the 200 lbs of paint flecks on the glue. The next day they clean up the loose paint flecks and then put down the patented sealer. Three days start to finish. You get what you pay for.
Old Oct 5, 2015 | 01:39 PM
glava2876's Avatar
glava2876
I had an epoxy quartz coating put down. I have a 2- 3/4 garage. As above, the first entire day 2 guys dud the grinder, next day epoxy and quartz, next day vacuum and epoxy and quartz again. Last day vacuum and polyurethane. Also color matched the cinderblocks to the wall color. The great thing is the floor has a texture that keeps it from being slippery, which is needed when we get 120" snow a year, but it still sweeps easily. Done about 1 1/2 years ago for $3,800.00.
Old Oct 5, 2015 | 01:42 PM
Rguy271's Avatar
Rguy271
Its a lot of work if you plan on doing it yourself. Prep is key. Get oil based, no water based stuff. You get what you pay for.
After looking at my options, I went with Racedeck over an epoxy. The racedeck goes down in two hours, and I can take it with me when I move which sold me on it.
Old Oct 5, 2015 | 01:50 PM
tomlink's Avatar
tomlink
+1 for Racedeck. About $800 shipped for my 10'x16' single-car garage.
Old Oct 5, 2015 | 02:11 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
The key to any epoxy job is that the floor needs to be prepped with a diamond cut blade and roughed up. If you simply paint the epoxy over the floor, the epoxy will lift with hot tires. Especially hot/wet tires.
Old Oct 5, 2015 | 02:13 PM
robert miller
Most good kits come with a pre-wash. What ever kit you go with go by the book on it on prep & mixing it together.
Old Oct 5, 2015 | 02:18 PM
C7cmnthru's Avatar
C7cmnthru
The company that did my polyaspartic coating took 3 days also. The heavy lifting was grinding the floor. A base coat then application of the "flakes" and the clear coat (2 coats).
Old Oct 5, 2015 | 02:41 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
My floor was uneven so I decided to tile it, $7.50 sq ft installed. Tile has a texture so its not slippery when wet.
Old Oct 5, 2015 | 02:45 PM
KaKruisin's Avatar
KaKruisin
I had mine done professionally in a heated and air conditioned garage. After a year or two I had some bubbles and lifting. They redid the whole floor, and again issues, so I went with Racedeck and love it.
Old Oct 5, 2015 | 02:48 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Nice job. Is it ceramic tile?
Old Oct 5, 2015 | 03:14 PM
DoubleDown's Avatar
DoubleDown
I would guess porcelain. For a garage you want a tile that is rated either a 4 or 5 on the PEI scale.
Old Oct 5, 2015 | 03:56 PM
Jud Chapin's Avatar
Jud Chapin
Is such tile rugged enough to handle jacking up a car on?
Old Oct 5, 2015 | 03:57 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
I used the Rustoleum two part garage epoxy patch then paint. Like everyone said before...PREP....two hours of work and it came out GREAT. And it was very inexpensive ....I think it was 35 bucks for everything at Home Depot.
To Epoxy Garage Floor
Old Oct 5, 2015 | 04:04 PM
DoubleDown's Avatar
DoubleDown
With a good tile that has been installed correctly you will have no problems with jacks, jackstands, dropping tools etc. As others have said in this thread, there is a lot of info on this topic on the Garage Journal forum.
Check out this thread, particularly the video in post #8
http://www.garagejournal.com/forum/s...d.php?t=219956
Old Oct 5, 2015 | 04:07 PM
CDH76's Avatar
CDH76
I'm a little late but hope to help. Do not buy epoxy kits from Lowes/Home Depot. Those kits are water based and will not last. Specially since you are in Houston. Come in from a hot day and hot tires you're going to peal that water based stuff off. You'll end up doing more work getting rid of it to do it right the next time.
I did my own floors and it's very simple. I would highly recommend you diamond grind your floors first. You can rent a diamond grinder from home depot for a few hours and knock it out. Make sure you were a mask. You do not want to breath that stuff in. I would go over it twice at least. I went over my floors about 3 times. Cleaned it up and did the epoxy the next day.
I used a 100% epoxy and bought the kit from epoxy-coat.com as they had good reviews and decent pricing. If you have any questions or need help let me know. I was a little worried doing it myself but it's very simple and easy to apply. Saved myself $800-1000 in labor cost.
Here some pics...
Old Oct 5, 2015 | 04:13 PM
CDH76's Avatar
CDH76
Here is one more with my baby inside. FYI black is hard to keep clean. I would suggest a gray. Easy to clean though!
