DIY: LTI intake valve cleaning/cleaning deposits
What the OP and other are showing here are NOT tearing apart the engine, only removing the intake manifold which is very easy with minimal tools if your somewhat handy. All gaskets are reusable and this also allows you to properly clean the oil already pooled in your intake manifold to be cleaned as well.
After you remove the intake manifold place it up on end and let the oil drain onto some paper towel or rags on the floor, then spray a can of brake clean inside it and swish it around and drain that. Let dry and reinstall. If you need more instructions, the OP can probably chime in or I have it in the C7 tech section as well.
The following 2 users liked this post by A471133:
COSPEED2 (10-30-2015),
Tron1 (06-18-2016)
The problem you face doing that is the deposits on a GDI engine are far greater than a old port injection engine, and the deposits are also hard and crystalline so when you do that procedure, you end up risking damage to the pistons and cylinder walls when the smaller particles break loose and are forced between the piston and cylinder wall and cause scouring (scratches).
I believe in nonGDI systems, fuel is a solvent and is constantly washing the valves; if you ran quality fuel on that hypothetical car there would be minimal deposits on the valves to wash off with a treatment, and therefore should have minimal chunks/hard deposits flying off into the combustion chamber. This is different with GDI is no fuel is keeping the back of the valves clean, oil and dirty stuff gets stuck on the back of valves, and over time bakes into hard deposits that accumulate on top of each other.
I'm Batman..
Pro Mechanic
Received 1,762 Likes
If the car is run hard & get hot it will form over into the intake.
Correct!!! The issue is not only this, but port injection and carbureted engines the deposits were relatively soft carbon and could be loosened and expelled out the exhaust with little chance of damage. GDI the valves are operating at such high temperatures that this are very hard and abrasive, and the amount of build up is so far greater. Port injection, even w/out running top tier fuel will rarely ever have any deposits on the intake valves due to the constant cooling and washing with detergent fuel (all fuel in the US must have minimum detergent additives), so you can examine a port injection head and see zero deposits even after 100-200k miles. Now look at these new GDI and see them in 2-5k miles.
And the deposits that build in GDI engines are wearing the valve guides at all times, and you really don't want to do a treatment every 1000 miles. Eliminate the cause at the source, and don't have to worry about it.
Bumping this back up for those that are looking for how to perform this properly.
Several problems with this. First, in order to be truly effective, the spray would have to be near constant. Most are boost referenced, so only spray during boost. Also, the cost to always refill the Meth is pricey in comparison over time to a proven system like the ColoradoSpeed or Elite Engineering E2-X system. Then one must look at the high compression ration of a DI engine (11.5:1 plus) will experience detonation as your introducing a combustible mixture to the cylinder during the compression stroke where pure GDI only introduces it milliseconds before ignition. SO this defeats one of the main advantages of GDI over Port injection. So yes, it does help slow the rate of coking, but is far from practical and is only partially effective.
While I admire your dedication to maintaining your car, I suspect that the average owner will quickly tire of doing this procedure every 5 or 10 K miles, especially if they have more than one DI engine to maintain. It's hard enough to get a lot of people to change their oil.
I have DI DD that has around 180K miles with no special attention paid to this issue, so I decided to give the CRC cleaner a try. I sprayed it thru the crank case ventilation tube inlet.
I think the car runs better but I haven't scoped the engine to see how clean the valves are.
So far, I'm pretty happy with the results.
#33
Received 3,043 Likes
St. Jude Donor '05
Run decent gas
dont lug the engine
Run it hard occasionally
No reason to tear your car apart all the time but to ea his own
dont lug the engine
#34
St. Jude Donor '15
Absolutely the best post ever for the C7! I know that I need to do this, but with 2 left hand and blind it is going to be tough to do.
I think that I will allow for a full day and no beers!
Thanks for this great post and the time you took to put it together, A471133.
Tron1 (06-18-2016)
#36
Does running the engine harder (keeping rpms up) as opposed to driving lazily (or slower with low rpms) help in diminishing coking on intake valves? If so, why? How does higher quality synthetic oil reduce coking problem?
#37
What happens is that pieces of carbon break off, and get stuck in the engine/behind the cats.
#38
#39
I agree that emptying a proper air/oil separation system every 5k is something 99% will not accept, that is why the "enthusiast" is generally the only owners to take these steps.
ALL service techs are instructed to not discuss this with the public.
as the public learns. They are all pushing like crazy now. Same with top tier fuels that used to be essential in keeping injectors clean and piston tops and combustion chambers clean are now useless. Watch the next Shell or Techron commercial on TV and how they claim to clean the engines internal parts (they do on port injection engines) and how most dealer service center push BG or similar for the profits$$.
Education is the best tool. Any further details or questions on anythong technical related to this and solutions. just ask.
Mobil 1 (06-20-2016)
#40
Jeez, this is even more trouble than owning a black car. Apparently, it's not worth the trouble owning a GDI. I do have one vehicle with GDI. Fortunately, it's a 2017 Volt. The engine never runs, so the GDI aspect shouldn't cause too much trouble...
