Rear Differential Replacement
Old Oct 13, 2015 | 01:34 PM
DBott1234's Avatar
DBott1234
Default Rear Differential Replacement
Hey guys,
To start off, I am no gear-head by any stretch of the imagination. I've had my C7 for almost 2 years now without many issues, but unfortunately experiencing some problems in the last few weeks.
It started out with a simple, "Rear Axle System turned off," warning sign. I got home checked the manual, and it said that sometimes it overheats and to let the car cool down and see if it happens again.
Waited until next day, went for a drive and sure enough it did it again. Called for an appointment and got in a few days later. They had it for a day or two and said that it was just a bad connection and that they replaced it and it's fine.
Fast forward a few days later, I get the same message. A little perturbed, I brought the car back in. The service department said they had never had this issue (not surprised, small town), and that they would be in touch with some GM techs.
Fast over two weeks later and the have replaced sensors, a module and god knows what else. They also sent all my specs to GM to review and GM isn't really sure what is going on either.
I was told that if this last Module fix didn't work, they were going to have to replace the rear differential. Obviously, like I stated earlier, and like most of you could gather reading my post, I'm unaware of the severity of this. I know it's an expensive fix for GM, that's about all I know.
I have checked into the local lemon laws and I do have some steps that I can take at this point, being that the car has been in the shop for 15 consecutive days. I'd be curios to get some of your thoughts on what you would do in my situation? I don't mind them fixing it, but is this going to De-value my car in the long run?
Thanks in advance,
DB
Old Oct 13, 2015 | 01:40 PM
Kracka's Avatar
Kracka
Let them replace the rear differential and continue enjoying the car, it's nothing worth worrying about in my opinion. It will have no impact on future resale value. I had a transfer case replaced under warranty once, that's what the 5 year/100k mile powertrain warranty is for.
Old Oct 13, 2015 | 02:04 PM
Nuclearranger's Avatar
Nuclearranger
Agreed, I had a Mustang that got two rear diffs under the power-train. Not that big of a deal, let them fix it, enjoy the car.
The lemon law probably won't apply to a two year old car anyway. Plus it's a pain to go through...
Old Oct 14, 2015 | 11:08 AM
DBott1234's Avatar
DBott1234
Thanks guys. Appreciate it!
Old Oct 14, 2015 | 01:47 PM
jamze132's Avatar
jamze132
Originally Posted by DBott1234
Hey guys,
Thanks in advance,
DB
I'm going through this as we speak. This first happened in the spring and I took it in and they said the fluid was low. I said yeah, I know, it's got a leak. They said they couldn't find the leak. I said it's on the inside as there are two tanks and when the inner tank leaks into the outer one, the "rear axle system off" message appears. They simply replaced the fluid and it was fine until 2 weeks ago. I took it back and again told them what the issue is and that it needs replaced. They said they needed to talk to the GM techs and once they did they had to pull off a module from the assembly line. Well I'm still waiting for my appointment so they can replace a part that isn't needed and to refill the fluid. And I'm sure I'll get another 4-5 months with no system warning.
I read the rear diff leaking thingy on a CTS-V forum as the systems are very close and have the same issues.
Old Oct 14, 2015 | 02:01 PM
TEXHAWK0's Avatar
TEXHAWK0
Another reason I did not want the electronic controlled differential...
I was afraid it might be prone to problems.
Old Oct 14, 2015 | 11:08 PM
And as mentioned earlier, it's probably too late for a Lemon Law claim (but you can check it out to be sure).
To Rear Differential Replacement
