2016 A/C Compressor...Help
Old Oct 15, 2015 | 06:19 PM
SIRWINSALOT's Avatar
SIRWINSALOT
7th Gear
From: Corpus Christi - sparkling city by the bay Texas flat lander
Default 2016 A/C Compressor...Help
2016. Z06/07 - Day after 500 mile oil change, ac. quit.
Like in hot air and green dye all over bottom of car and snout of compressor . Dealer says it's shaft seal and replacement of compressor will be required.
The very young mechanic mentioned the cradle must be lowered to do job.
My question is can it be done without cradle drop ?
Maybe from top with air box & alternator removed.
I know many jobs have shortcuts to save time over shop manual directions.
Not wanting all that disturbed on such a new vehicle.
Also my area isn't known for repair of such vehicles in any volume to speak of and any work will probably be a first for the mechanic and shop.
Old Oct 15, 2015 | 06:22 PM
bbcb's Avatar
bbcb
sorry to hear that stuff with 500 mi. good grief !
Old Oct 15, 2015 | 07:45 PM
SIRWINSALOT
7th Gear
Thank you for the sympathy.
I originally thought ac delete would be cool. let me tell you in S.Texas could not be farther from truth. Not cool pun intended.
Someone has to know if compressor can be removed from top.
Old Oct 15, 2015 | 08:38 PM
GS1960's Avatar
GS1960
There are often many ways to replace something. Hopefully, someone will respond to this thread that knows something.
Old Oct 15, 2015 | 09:15 PM
SIRWINSALOT
7th Gear
I have seen pics with upper components removed and it seems somewhat accessible.
Seems pretty major to drop cradle for compressor swap. Lots of items disturbed that are in factory fresh condition.
Old Oct 15, 2015 | 09:20 PM
bob guzzy's Avatar
bob guzzy
If they can do it without dropping it they won't drop it, they might remove the motor mounts then lift the engine, I highly doubt they will drop the cradle.
You don't do anything that involved to replace a simple part like a compressor.
Old Oct 15, 2015 | 09:22 PM
SIRWINSALOT
7th Gear
Would love to be able to recommend an easier top access way to do it. Assuming dealer mechanic would follow any instructional advise.
Old Oct 15, 2015 | 09:27 PM
SIRWINSALOT
7th Gear
The dealer shop manual says so. lower cradle. yes i agree they will use easiest method presuming the young mech. knows one. If anyone does since such a new design.
Old Oct 15, 2015 | 11:42 PM
owc6's Avatar
owc6
I hesitate to bring this up, but this is exactly what I was told on my '05 when the A/C compressor went bad.
How similar is the arrangement of the C6 and C7 components under the hood and their accessibility?
To 2016 A/C Compressor...Help
