Down a quart at 500 miles.
Old Oct 22, 2015 | 03:55 AM
xcpilot's Avatar
xcpilot
Default Down a quart at 500 miles.
I pulled my dipstick to check my oil last night on my 2016 Stingray and YIKES it was down a liter (that's a quart in English). I am still on my second tank of fuel! We are leaving Canada Saturday for the west coast to see the Redwoods and drive the coast highway. I hope I am not adding a quart every day. Dealer topped it up this morning, maybe it was low when delivered last week-hope, hope. This is a wet sump engine BTW.
Old Oct 22, 2015 | 04:04 AM
Black&White's Avatar
Black&White
That is not normal. However it could have been a low fill from the factory. Make sure the car is level and standing off for at least 20 mins before checking the oil level. Check it every morning take a photo of the reading for proof.
Old Oct 22, 2015 | 06:39 AM
Larry/car's Avatar
Larry/car
I wouldn't say it is not normal. My car used a Qt first 500 miles and now at 5000 miles it uses virtually none. Others here on the Forum have experienced similar, a few engines continue to use oil. Thinking, the power this engine produces prevents drivers from pulling sufficient power to seat the rings. (once you glaze the cylinders, takes forever if ever to undo) Try some high power pull outs on a sufficient grade to push out the rings against the cylinder walls. That is what I did and now all is fine.
Old Oct 22, 2015 | 09:19 AM
Corgidog1's Avatar
Corgidog1
My car was down a quart in its first 1000 miles and so far has not used any oil for the last 800 miles.
Old Oct 22, 2015 | 09:51 AM
Red C8 of Jax's Avatar
Red C8 of Jax
As mentioned, check everyday, might get worse. Good luck on your trip.
Old Oct 22, 2015 | 03:22 PM
2HD's2vettes's Avatar
2HD's2vettes
Are you checking it after being parker awhile? Isn't it supposed to be checked "hot" on the dip stick? My Z51 (2016 @ 580 miles) is roughly a quart low, but per the label on the oil fill, When I bring engine temp to 175 degrees, and check it - it's spot on.
Old Oct 22, 2015 | 04:31 PM
bbcb's Avatar
bbcb
Base c7 dip stick is a pain in the neck to even read ...or is it just me ?
Old Oct 22, 2015 | 04:45 PM
carpe dm's Avatar
carpe dm
Old Oct 22, 2015 | 05:03 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I thought mine was down a quart but after letting it sit for about 15 minutes the oil came up to the halfway mark on the dipstick. I just passed 2500 miles and will be doing an oil change myself using Mobil1 and a Mobil oil filter tomorrow. I'll have the dealer do one when the DIC says it is down to 20%.
Old Oct 22, 2015 | 05:08 PM
xcpilot's Avatar
xcpilot
I think I will take your advice and runs it through the gears a few times. I has not been totally babied during breakin. I have pushed it a few times as did a couple of other persons I allowed to drive it.
To answer others, yes the car was parked level in my garage and I checked it several times over the course of an hour so there was ample time for oil to return to the pan.
And yes these dipsticks are a pain to read.
Thanks to all for the comments they are appreciated. I will try and get a photo of my car in the drive through tree and post it here.
Old Oct 22, 2015 | 10:56 PM
I'd just keep an eye on the level and see how it does. If it continues to use oil, have it checked by the dealer.
Old Oct 22, 2015 | 11:37 PM
owc6's Avatar
owc6
It is normal to burn oil during the break-in period (1500 miles). Enough so, that it is recommended to to check the oil level at every fuel fill.
If this continues after, then it's time to sound alarms and have it checked.
Not all cars burn/consume oil during this period, but it's not abnormal to do so.
Old Oct 23, 2015 | 11:40 AM
Jim Barker's Avatar
Jim Barker
I would still give it and early oil change even though it's a wet sump car. I did on mine at 1000 miles. Its always been part of the preventative maintenance for me on new or rebuilt engines to flush them.
Old Oct 23, 2015 | 12:23 PM
jyounger74's Avatar
jyounger74
My 14 stingray did the same thing. I added 1 quart and installed a catch can. No more issues, these engines need the catch cans to prevent the oil being sucked through the PVC into the throttle body. These LX motors have been doing this since the insepsion of the C5's. I have owned 4 vettes and installed catch cans on everyone of them.
To Down a quart at 500 miles.
