Rolling Issue
Old Oct 22, 2015 | 09:58 AM
cashcrew's Avatar
cashcrew
Default Rolling Issue
I'm wondering if anyone has experienced a "Rolling " issue w/the C7 manual 7-speed stick. The car rolled, while in gear & e-brake on, ever so slowly. Its happen twice & has caused cosmetic damage. I took it to the dealer & they tested it on decline. Sure enough, it "Rolled" every so slowly, but still rolled. I've since taken back again & they say the problem is fixed. GM paid for the damage, but I just want to know am I the only one this has happened to?
Old Oct 22, 2015 | 10:03 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
My manual has never done that, parked on inclines with ebrake only, no rolling. I hope they fixed it for you!
Old Oct 22, 2015 | 10:04 AM
dvilin's Avatar
dvilin
Have not had that problem thankfully.
Old Oct 22, 2015 | 10:05 AM
Ernest_T's Avatar
Ernest_T
I don't have a manual, but with the e-brake on and the car in gear it won't move even if I push on the gas. I think I'd have to give it quite a bit of throttle to get it to move.
Old Oct 22, 2015 | 10:06 AM
vettnutt's Avatar
vettnutt
No such issue here.
Old Oct 22, 2015 | 10:07 AM
TEXHAWK0's Avatar
TEXHAWK0
The brake should hold it even if it is not in gear....
Also, you might try parking it in a lower gear...
Old Oct 22, 2015 | 10:12 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Something is weird. Obviously the parking brake doesn't work properly on the OP's car, but I can park mine on an incline in 1st gear without the parking brake enabled and it isn't going anywhere.
Old Oct 22, 2015 | 10:23 AM
cashcrew's Avatar
cashcrew
Hey, thanks you guys/gals......I appreciate all of your responses. They say the problem has been corrected & I have not had it "Roll" since getting it back from dealer.
Old Oct 22, 2015 | 11:15 AM
TNSQUIRE's Avatar
TNSQUIRE
It would be interesting to find out what the problem was that they fixed.
Old Oct 22, 2015 | 11:23 AM
SCorvette08's Avatar
SCorvette08
what was the fix that should tell you the problem tell us
Old Oct 22, 2015 | 11:47 AM
monicatomokc's Avatar
monicatomokc
I don't have that problem, but I would like to know too.
I use the electronic brake all the time on an incline at stop lights to prevent roll-back into those knuckleheads that pull up inches behind you!!
Old Oct 22, 2015 | 11:51 AM
cashcrew's Avatar
cashcrew
TNSQUIRE, What was happening is the dash display was say "SERVICE REAR AXLE"...then, when I put on the e-brake it would lock up the rear end & the car wouldn't even start. I thought it was going to have to towed to the dealer. Given the fact she's so lowered, I had concerns for getting her onto a flatbed. Well, low & behold, the e-brake finally disengaged & it started. Dropped it off at the dealers & when I picked it up, the dash display was cleared of the "SERVICE REAR AXLE." Since getting it back, I've not had any further issue w/it? Go figure
Old Oct 22, 2015 | 11:55 AM
cashcrew's Avatar
cashcrew
I know what you mean about folks pulling right behind you, especially w/a 7-speed stick. I, myself let the car roll back & forth on "Stopped Inclines" I balance the clutch & gas pedal just so the driver behind knows that I have a stick & not get to close.
Old Oct 22, 2015 | 12:22 PM
Hoonose's Avatar
Hoonose
I had this happen with my C6 and all I remember is that they fixed or adjusted the parking brake so it held firmer.
Old Oct 22, 2015 | 12:42 PM
ratman6161's Avatar
ratman6161
That's a fairly significant piece of information missing from the original post. Curios what they found as the actual underlying problem???
Old Oct 22, 2015 | 01:33 PM
monicatomokc
Yep, I hear ya. I worry about that extra wear & tear on the clutch though, hence the reason I use the EPB so much on those inclines and interested in what caused the failure with yours.
I love this forum and the info we get on things like this and if we experience the same problem, we're one step ahead when we bring it in for service!! Thanks for posting!!
Old Oct 22, 2015 | 01:37 PM
TNSQUIRE's Avatar
TNSQUIRE
This is where hill start assist comes into use.
To Rolling Issue
Old Oct 22, 2015 | 02:19 PM
cashcrew's Avatar
cashcrew
Yes, it appears that the problem has been appropriately addressed. I've had no further issues, thus far?
Old Oct 22, 2015 | 02:22 PM
cashcrew's Avatar
cashcrew
Absolutely, this community has helped me right out of the gate. It's nice to hear from the individual w/the C6, who experienced this same situation.
Old Oct 22, 2015 | 02:23 PM
cashcrew's Avatar
cashcrew
They never said exactly, but assured me it was corrected....we'll see.
