NoviStretch @ CCA - C7 Corvette
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
NoviStretch
Front End Covers
NoviStretch's Durable, Breathable, Quality Material protects paint the
paint surface from common daily wear without damaging Clear Coat
Paint Finish.
Stretchable fabric allows for a tight, secure fit around the front bumper.
Unique material and design allows for easy cleaning, quick drying and
compact storage when not in use.
The NoviStretch "Snap and Strap" easy on and easy off installation
hardware is all hidden from view and does not require and permanent
modification to your Corvette.
Paint Finish.
For more information or to get yours today
Please follow the link below
NoviStretch Front End Covers
Regards
Chip
NoviStretch
Front End Covers
Paint Finish.
Paint Finish.
Regards
Chip
Will this work with a OEM Z06 splitter installed? Only the splitter, not the side winglets. Thanks!!
With my bad back I don't like having to loosen the air dam corners to accommodate the corners of the bra. Any ideas about making a small part to hook the corner on, permanently attaching it using the corner air dam screw?
CCA Corvette Parts (07-25-2016)
