When starting my C7, the starter always cranks for approx 2 seconds before the engine starts. My C5 always started in a micro second. Is this normal for the direct injection engine.
my understanding is that it's the engine pressurizing the fuel system since it is a Direct Injection engine, where fuel is sprayed at, if i recall, a few thousand PSI
I have the same issue it cranks for a little before it actually turns over. BMW's do this also. I just assume it to be normal. When it dosent start at all then clearly there is a problem
Funny you asked this question. I was wondering the same thing shortly after I got my C7 and thought it was strange how my C6 would fire up right away, but sometimes after hitting the start button in my C7, it will crank a good two seconds or so and then fire up. It was a relief to know this is perfectly normal for the DI engines in our C7
nope, oil pressure can't come up until there's sufficient engine heat. It's for fuel pressure.
What??? Oil pressure is at its highest when the oil is cold. When things heat up, oil pressure goes DOWN because the viscosity of the oil drops with greater heat. Don
Actually, darn it, I might be wrong W88! Am I inverting how it works? You need the oil to be a certain temp before VVT works, i think I'm conflating pressure and temp.. Nothing Google can't straighten out for me..
Now that I think about it I remember when I had my '01 Grand Prix GTP, on cold winter days, I would have to turn the key to the on position and wait for a second or two until I heard the fuel pump cycle otherwise I would have one hell of a time starting the car. I'm guessing that's what is happening here except it does it automatically. But I'm an IT guy so I could be totally wrong.
Me too, but the way things are going I think in a few more years, we will know more about cars than mechanics
Wouldn't be surprised if the oil needs to be warm for VVT but I don't claim to know much about it. Perhaps they want the engine to be warmed up before playing with cam timing for emissions sake. Would be interesting for a subject matter expert to chime in. Don
