Oil life reset
Old Oct 29, 2015 | 04:50 PM
bbcb's Avatar
bbcb
Default Oil life reset
Being relatively new to my C7 ...I reset the oil life monitor when it was at 86% ..now it reads 100 % ..anyway to restore the 86 % which is where it should be ...or just live with it ? tks
Old Oct 29, 2015 | 04:52 PM
DickieDoo's Avatar
DickieDoo
just change the oil when it gets to 25%
Old Oct 29, 2015 | 04:53 PM
6104696's Avatar
6104696
change the oil. then all is good.
I don't think that you can set it to anything other than 100%.
Otherwise, just live with it and remember to change it well before it gets to zero. I rarely let it go much below 25% anyway.
Old Oct 29, 2015 | 04:59 PM
owc6's Avatar
owc6
Old Oct 29, 2015 | 05:16 PM
Curahee's Avatar
Curahee
Owners Manual says oil is good for 7,500 mi.
Old Oct 29, 2015 | 05:51 PM
BigTree's Avatar
BigTree
OK, I'll ask -- How do you reset the oil monitor?
Old Oct 29, 2015 | 06:12 PM
owc6's Avatar
owc6
Default Resetting the OLM
In Info on the DIC, scroll until you get to Oil life. Press the right button on the lower right of steering wheel. Scroll to reset, press Sel.
Presto, 100%!
Old Oct 29, 2015 | 06:49 PM
Larry/car's Avatar
Larry/car
The engine will not fail if the oil life isn't spot on. The oil life monitor system counts calendar days in addition to mileage. In reality you could not travel a mile and the oil monitor will count down to zero.
Old Oct 29, 2015 | 06:57 PM
speedlink's Avatar
speedlink
Go by the oil monitor! At around 5-10% change the oil. 7,500 miles is a guide line for mileage. Use the percentage. It uses an algorithm based on engine revs and heat while operating, as well as days, to judge the remaining approximate oil life.
Old Oct 29, 2015 | 08:31 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Since nobody has really answered your question, no, you can't "restore" the 86% reading or any other number less than 100%.
Old Oct 29, 2015 | 09:00 PM
dbdave's Avatar
dbdave
A dealer can restore the oil life but don't bother. The car's not going to stop, the engine is not going to blow (due to this), the oil is not going to dissolve, and the IRS won't come after you if you're off a few percent the next time you change oil.
One of the factors that will cause the percent remaining to go down is time since last changed, like was mentioned above. Just by letting the car sit will cause the percent to lower so being off by a few percent is no big deal.
Old Oct 30, 2015 | 06:32 AM
I agree with just changing the oil a tad early next time. Car will be fine.
Old Oct 30, 2015 | 06:57 AM
C7Joy's Avatar
C7Joy
If you are still wishing your free oil change period of two years, just have your dealer do a change and reset again.
Old Oct 30, 2015 | 09:01 AM
bbcb's Avatar
bbcb
thank you ...
Old Oct 30, 2015 | 09:39 AM
TEXHAWK0's Avatar
TEXHAWK0
That is the solution....Just don't drive your car until the OLM gets down to 86% again!
Old Oct 30, 2015 | 10:22 AM
owc6's Avatar
owc6
Old Oct 30, 2015 | 10:27 AM
defaria's Avatar
defaria
As I understand it, changing oil frequently is often unneeded. Back when I had the 08 I'd change my oil about once a year. Never had a problem. Also, from this Edmunds article:
Synthetic oils, such as the popular Mobil 1, are stretching oil change intervals, leaving the 3,000-mile mark in the dust. "The great majority of new vehicles today have a recommended oil change interval greater than 3,000 miles," said Mobil spokeswoman Kristen A. Hellmer. The company's most advanced synthetic product (Mobil 1 Extended Performance) is guaranteed for 15,000 miles.
To Oil life reset
Old Nov 2, 2015 | 05:34 PM
speedlink's Avatar
speedlink
You don't need a dealer to reset it. You can do it yourself. Just follow the manual. Its reset via the the settings on your touch screen.
Old Nov 2, 2015 | 06:39 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Hmmmm.... Are you sure? Mine is reset on my DIC.
Elmer
Old Nov 2, 2015 | 07:25 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by defaria
As I understand it, changing oil frequently is often unneeded. Back when I had the 08 I'd change my oil about once a year. Never had a problem.:
Did the same with my '08 at a year because the oil monitor still showed some mileage left. The difference with the C7 it not only says change after a year max time is also is in the oil monitor algorithm! If you don't drive enough it will say change when the year is up.
