From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
A8 Problem?
I was driving my 2015 Z-51 A8 with 2,700 miles on it today on the Interstate. I was one mile from my exit passing an 18 wheeler going about 70. I punched it down and ran up to 105 and let off. As I was slowing down to 55 to exit the car was racing and the tach was at 3500 rpms. When I got stopped at the exit the car seemed like it was still in an upper gear. The car was racing and wouldn't shift normal. I pulled out and started driving and it went back to normal. I didn't get a chance to punch it down again to see what would happen?
My first thoughts were this seem like a computer problem? What is the TSB for the transmission?
Any thoughts?
Any thoughts?
Normal behavior. Car went into Performance Shift mode and indicated it on the DIC.
When you mash the loud pedal, the car shift algorithm changes such that the car stays in gear longer and won't upshift assuming you are asking for more performance. The transmission will return to normal shifting when you let off the pedal long enough, or you can hold the upshift paddle and it will return to normal shifting (if you are not in manual shift mode).
Ed, part of what you describe sounds like exactly what happens when the performance algorithm is activated which provides more aggressive gear selection by holding the lower gear assuming you will be continuing with aggressive driving. This has been included in the programming of a number of GM automatic transmissions for close to a decade now. However I am not exactly sure what you mean by being stopped at the exit and the transmission was in a higher gear with the car (engine?) racing? If you literally were at a stop with brakes applied then that certainly isn't normal but if you meant you were just driving slowly after coming off the interstate it could well have stayed in the performance shift mode since turns/curves are one of the parameters that engages this mode.
NSC5 I did what you describe. Can this feature be turned off in sport or track mode?
I don't think the transmission performance shift feature can be disabled in Sport or Track modes.
If you put the transmission in Manual mode and shift with the paddles, you will have complete control.
I don't believe there is any way to turn this off but you might try a manual paddle upshift to see if that will exit the algorithm. However this would only exit it until the next time your driving input triggers this mode.
It is actually a very nice feature once you get used to it and the intent is to provide the maximum performance possible. It is disconcerting the first time you experience it. I had just gotten through the break-in period of my 2008 Cadillac CTS when I first experienced the PAS/PAL (Performance Algorithm Shifting/Performance Algorithm Liftfoot) behavior. I had gone to near full throttle on an interstate on-ramp after the mini-van in front of me decided to pull off on the shoulder midway down the ramp and once on the interstate the transmission stayed in a lower gear for a short time leading you to first believe you are in some sort of limp mode. GM really needs to explain this behavior very early in the manual because there are a lot of questions/concerns across the various models from owners who aren't familiar with this behavior.
Normal, scared the crap out of me when it happened though. I also was in the sport mode. It discusses this feature in the manual, but it is rather vague.
Originally Posted by Corvette ED
Rick T I was in Sport Mode
Maybe up shift manually up shifting and downshifting and see how it does.If it behaves better
Maybe go that route in the future.At least you have options.
Mine moves out of PS mode faster in Touring and Eco modes, which is why I've been using Touring mode most of the time. In most conditions I don't need Performance Shifting to be activated and in those times find it irritating.
