Rice or Nice?
Old Nov 2, 2015 | 11:13 PM
efarley's Avatar
efarley
Default Rice or Nice?
Playing with the idea of painting a 1/4 inch pin stripe along the bottom of my front splitter and side skirts before I install them so I found a picture of a car and photoshopped it to get an idea. I'll be adding red rim guards as I have issues with curb rash for sure, it's just the pin strip on the bodywork that's being discussed here.
My thoughts? I think it might be nice. I'm looking for something subtle and tasteful that adds a little bit of POP to the car and ties the splitter/side skirts into the rest of the car (although the carbon fiber already does this). Now that you know my thoughts/goals what are yours, rice or nice?
Old Nov 2, 2015 | 11:17 PM
MeanDean43's Avatar
MeanDean43
I think it blends in very well with the rim guards!
Old Nov 2, 2015 | 11:38 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
JMO, but since you asked-rice.
Old Nov 3, 2015 | 12:16 AM
millpond's Avatar
millpond
In my opinion...rice. But, whatever turns your crank.
Old Nov 3, 2015 | 12:28 AM
Dif's Avatar
Dif
Can't really say it looks bad, but it borders on too much going on.
The red rings on the wheels look to be just enough without adding more pin striping else where
Old Nov 3, 2015 | 12:44 AM
douginkc's Avatar
douginkc
you will regret it when > not if > you need touch up the paint. Black is an easy touch up, black with a red stripe is not.
Old Nov 3, 2015 | 12:57 AM
efarley's Avatar
efarley
It's exposed carbon fiber. There is not touching it up.
Old Nov 3, 2015 | 12:59 AM
nmvettec7's Avatar
nmvettec7
I really like the red trim on the front splitter and side skirts. The addition of the red trim on the wheels makes the idea a bit overpowering.
I would suggest that you do the front splitter and side skirts first. Drive the C7 for a while and see how you like it. Then consider doing the rims.
The addition of the trim on the rims turns the C7 into a "rice burner" look.
Other C7's that have the splitter/side skirt trim looks fine like Steven Bell's. Actually, his looks classy. Your's could be the same.
Old Nov 3, 2015 | 01:11 AM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
Looks good to me. Who cares what the yahoos here think.
Old Nov 3, 2015 | 01:35 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I wouldn't paint on exposed cf. Carbon flash yes, it looks sharp especially on torch red. Oreillys had some 1/4" pin striping in lots of different colors. You could always pick up red for $3 to see what it would look like.
Old Nov 3, 2015 | 06:12 AM
Frodo's Avatar
Frodo
I like the idea of an accent and you might be on the right track. You can try different ideas with pin stripe tape and see what you like. As some have suggested, it appears a bit busy as it sits in the picture. A thinner pinstripe might not look so busy, you know, one that a casual observer may even miss but an admirer might say "Wow, check that out. I didn't see the matching pinstripe at first." Good luck and post pics of what you come up with.
Old Nov 3, 2015 | 06:56 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Y'all beat me to it. It's your car. you paid for it. As Rooster suggested, do the tape thing first. Then if you like it, go the paint route or, simply leave the tape. Much easier to remove at a later date if you get tired of it.
Old Nov 3, 2015 | 06:59 AM
C7Joy's Avatar
C7Joy
I don't think I would.
Old Nov 3, 2015 | 07:15 AM
gottspd's Avatar
gottspd
I think it looks cool. I'm particularly interested in the rim rings you're going to use. Can you tell us more about those?
Old Nov 3, 2015 | 07:45 AM
dvilin's Avatar
dvilin
Old Nov 3, 2015 | 08:10 AM
I think your idea looks pretty good on the car. I would agree with just using some pinstripe tape first and give it a while to see just how you like it. Good luck with whatever you decide.
Old Nov 3, 2015 | 08:19 AM
1SG_Ret's Avatar
1SG_Ret
I like the look. Matches everything else perfectly IMO.
To Rice or Nice?
Old Nov 3, 2015 | 08:34 AM
DCortez's Avatar
DCortez
Red and black looks nice.
Old Nov 3, 2015 | 08:40 AM
GLENK's Avatar
GLENK
Looks awesome to me!
Old Nov 3, 2015 | 08:42 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Its your car, if you like it go for it. I don't worry about what OTHER people think about MY car.
