Was wondering if anyone else has had this happen and if they have found a remedy.
Mine did the same. Your dealer will replace it under warranty. They replaced mine and will probably have to do it again. When They replace this one I am going to find a matching aftermarket pad or something to protect it. Or I'll keep making them replace it until warranty runs out.
This was pointed out in a post here about a month or two ago. OP in that post noted what looks like the same issue, then a day later when the car was heated up in the sun, noted that the indent/bubble went away.
I had my car for a day, then the saw the indentation and loose material on my center console top cover. I'm lucky to work in the Detroit and have resources available to me. Lear Seating is the Supplier and has know about this issue for at least 18 months. There response is the have to car sit in a "Hot day" to allow the leather to shrink to size. Much of comedian... How about fixing the sizing and fitting of the leather to the component!
