Dash center section
Old Nov 7, 2015 | 02:27 PM
Cirrus8's Avatar
Cirrus8
Default Dash center section
Some how I managed to get my radio information in the center section. I want to get back to the info that shows tire pressure and other stuff. How do I get back to the tire pressure screen?
Old Nov 7, 2015 | 02:48 PM
defaria's Avatar
defaria
What I have you tried? I mean seriously. There are a ton of settings and things you can do and you haven't been playing with them at all?
On the steering wheel use your right thumb to press the button to put it into the center screen. Now you can use ^ and v to cycle up and down through the various gauges that the Info and Performance offer you. There's also things like Audio (which I like because then ^ and v do previous and next song) and Nav, which is OK. Note that some selections such as Audio, once put in the center display have an option to use > to expose another menu on the right side this time. From Audio, for example, clicking right (>) allows me to select the audio channel (radio, USB, Bluetooth, etc) as well as Browse artists and playlists, etc.
Good luck. And play around and learn. That's how it's done.
Old Nov 7, 2015 | 03:16 PM
Kev4's Avatar
Kev4
Well for one thing, the car must be running to get tire pressures to display.
Old Nov 7, 2015 | 04:20 PM
Bucknut2006's Avatar
Bucknut2006
There is a secret decoder ring in your car called an owners manual. If that doesn't work, there are stickies at the top of the C7 section.
Old Nov 7, 2015 | 07:19 PM
Cirrus8's Avatar
Cirrus8
Thanks all. I finally figured it out. I got into the "audio" mode while trying to figure out why I had no sound from any source. I had accidentally touched the OnStar logo on my rear view mirror when adjusting the mirror. OnStar came on and stayed on thus blanking sound from any other source. So I tried the left arrow in the right thumb control and got the options for selections one of which was "info". Selecting "info" brought back the screen that I was searching for!! HooYa!!
To Dash center section
