Car jerks when turning
Old Nov 7, 2015 | 05:30 PM
timmyg789's Avatar
timmyg789
Default Car jerks when turning
My 2016 only has 2000 miles... If I turn my wheel the entire way to the left or right it will jerk and skip forward. Should it be turning smoothly when the wheel is turned the whole way or is this what they all do?
Popular Reply
Nov 7, 2015, 11:55 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Elmer
Old Nov 7, 2015 | 05:35 PM
C7HOORAY's Avatar
C7HOORAY
Totally normal....your delivering dealer should have told you to expect it.
Old Nov 7, 2015 | 05:39 PM
millpond's Avatar
millpond
The owner's manual even talks about it.
Old Nov 7, 2015 | 05:57 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Yup. It's the style of tires. Not a problem with the car.
Old Nov 7, 2015 | 06:34 PM
C8-Vette's Avatar
C8-Vette
Had the same situation with my C6 . Thought it was a problem with the rear end clutch packs, so I changed to synthetic rear end fluid. No change. I was never told about situation with the tires. It happens with the new C7- Z51 especially on colder days. I'm no longer concerned.
Old Nov 7, 2015 | 06:55 PM
mksz51's Avatar
mksz51
Ackerman Steering Principle. Check it out.
Old Nov 7, 2015 | 06:57 PM
mksz51's Avatar
mksz51
The primary cause is the steering geometry. The tire choice just exacerbates it.
Old Nov 7, 2015 | 06:59 PM
green2000's Avatar
green2000
Yes, and lower temperatures accentuate it.
Old Nov 7, 2015 | 07:00 PM
mksz51's Avatar
mksz51
Depending on the tires you have.
Old Nov 7, 2015 | 08:01 PM
timmyg789's Avatar
timmyg789
Ok thanks for the info guys this is the first time I have ever had a car that does this.
Old Nov 7, 2015 | 10:56 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
It is the race car style Michelin tires. Especially the lower profile larger Z51's. Had the same size tires an "Ackerman" steering geometry on my Z51 C6 and it wasn't close to this bad. Gets much worse when below 40F. At 30 will feel like front end is falling apart if you use full lock at very slow speeds like when backing or pulling out of a parking place. Of interest folks who switched to all-season tires indicate the issue goes away or is significantly reduced. Did some research and summarized the issue in this PDF: www.netwelding.com/wheel_chatter.pdf
Simple solution. When tires are cold don't make full turn, leave 1/2 turn from full lock and make a "K" turn!
Old Nov 7, 2015 | 10:58 PM
HANNY's Avatar
HANNY
interesting thread
Old Nov 7, 2015 | 11:55 PM
eboggs_jkvl
Moderator emeritus
Elmer
Old Nov 8, 2015 | 08:58 AM
JerryU's Avatar
JerryU
Gets worse as it gets colder. Expect like in the past two winters, some folks will be bringing their new car to a dealer!
My C7 is a September 2013 build and a DD so have experienced two winters. In 2013 someone posted they were pulling out of a parking slot on a cold night after the car had been parked for some time. He turned the wheel full lock and thought something had failed. He got out of the car and looked underneath. His wife wanted him to leave it parked and call the dealer to have it towed! If you have a Z51 and it gets to ~35F, be prepared or follow my previous advice and turn less than full lock when making slow turns! When I pull out of the garage in the morning, that's what I start doing around this time of year and make a "K" turn where in the summer no vibration or chatter at all. Even the non Z51 will experiance chatter, as GM calls it.
Old Nov 8, 2015 | 09:06 AM
4thC4at60's Avatar
4thC4at60
My C6 and my V-Caddy did the same thing.... normal...
Old Nov 8, 2015 | 09:17 AM
Glen e's Avatar
Glen e
A brand new 911 does it....it's a simple engineering way that you get the car to have a shorter turning radius. It is engineered in the vehicle on purpose.
Old Nov 8, 2015 | 09:23 AM
TBIRD57's Avatar
TBIRD57
Default even more interesting?
Originally Posted by HANNY
interesting thread
that crap like this is accepted as "normal" in this day and age.
To Car jerks when turning
Old Nov 8, 2015 | 09:29 AM
BIG Dave's Avatar
BIG Dave
Originally Posted by TBIRD57
even more interesting? that crap like this is accepted as "normal" in this day and age.
GM could have engineered the vehicle to have a larger turning radius. But then people would complain the competition has a shorter turning radius. Can't have it both ways.
Old Nov 8, 2015 | 09:52 AM
eboggs_jkvl
Moderator emeritus
Well, this crap allows for the car to handle better while driving. I usually don't have the car in full lock doing 70 MPH.
This is normal for a sportscar type of handling with very wide tires. Chill...
Elmer
Old Nov 8, 2015 | 10:01 AM
JerryU's Avatar
JerryU
It's not crap, it's the racing type tire construction that makes the car achieve the high "g" forces many of us enjoy! For more gear head oriented folks, I'll try with one pic of the many in my PDF to describe why it happens with the OEM tires and goes away with all-season tires. For those that just roll your eyes with a tech explanation just continue to blame GM and call it crap!!
Racing type tires are built to have very low slip angles, i.e. turn the wheel and the contact patch follows instantly. The low profile run flat, stiff sidewall Michelins, especially on the Z51 are close to race car tire performance. When these tires are turned sharply at low speeds there is little movement or squirming on the surface. Even with some Ackerman steering geometry built in, one tire skids across the pavement causing chatter. A colder stiffer tire is worse. Ackerman invented and patented the idea of turning each front wheel at a different angle in small turning radius turns. He did that for horse draw carrages in 1816 and it can help at slow speeds.
But excess Ackerman geometry is worse at higher speeds where the tires operate at a different slip angles side to side since lateral forces are higher on th outside tire in a high speed turn. Suffice to say the steering geometry in the C7 is optimized for high speed performance not to make those unwilling to turn the wheel less on slow speed, sharp turns when it's cold!
If you are not willing to turn the wheel less, suggest buying an Impala, etc!
As mentioned my Z51 C7 is much worse at 30 to 40F than was my C6 Z51. Never had to turn the wheel less when pulling the C6 out of the garage on a cold morning with the OEM Goodyears or the Firestones I put on after. There as some chatter but minimal. With my C7 I do it when it's less than ~45F, no big deal!
Large Slip Angles Need Less Ackerman Geometry to Avoid Chatter, Since Tread Moves Reducing Sliding or Skidding. So C7 Owners Who Switch to All-Season Tires Have Reported the Chatter Issue is Eliminated or Significantly Reduced.
