Light bulb upgrade
Nov 7, 2015 | 09:52 PM
Light bulb upgrade
I bought a bunch of high output bulbs for the C-7
Does the C-7 already have these brighter bulbs for example in the license light interior lights etc.
Nov 7, 2015 | 11:07 PM
No they don't! The license plate bulbs and the trunk light bulbs should be changed out to the brighter bulbs.
Nov 8, 2015 | 12:18 AM
Where can you buy the light bulbs. Do you have part numbers or descriptions?
Nov 8, 2015 | 12:29 AM
Quote:
Originally Posted by
MeanDean43
I'm very much pro LE but having said that, who in the hell wants to make the license plate more visible? Don
Nov 8, 2015 | 02:52 AM
St. Jude Donor '15
I bought these, they work great. I think I had two broken in the bag, but it wasn't worth sending them back, to me at least.
Nov 8, 2015 | 06:53 AM
w88fixer
i'm very much pro le but having said that, who in the hell wants to make the license plate more visible? Don
good point either way they see it though
rooster og
i bought these, they work great. I think i had two broken in the bag, but it wasn't worth sending them back, to me at least.
amazon.com: Generic 2014 newest, 4th generation, 20pcs ,w5w 194 168 2825 t10 wedge 5-smd 5050 white high power car led lights bulb,brighter,green energy, lower heat, eco-friendly,better quality,longer life: Automotive
yep that is the ones i bought great price will install today
Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner of each post!
Nov 8, 2015 | 07:36 AM
Are these bulbs for the trunk or license plate? I want to swap out the trunk lights so they match with the front interior LEDs.
Nov 8, 2015 | 07:42 AM
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
blue max
Use them as well.
Nov 8, 2015 | 08:47 AM
St. Jude Donor '15
l.i. bruce fan
Trunk and license plate, same fixture. I was too lazy to do the plate, the cargo area was easy.
Nov 8, 2015 | 08:57 AM
W88fixer
put in a dimmer bulb or a darkened license plate cover.
Nov 8, 2015 | 01:16 PM
Larry/car
I had a cover that was supposed to impair red light cameras. Hardly had it a day and security at Kirtland AFB saw it and ordered me to remove it.
One day my LE son saw me washing the car and the license plate and said don't bother with washing the plate. Don
Nov 9, 2015 | 07:54 AM
W88fixer
Those who want a white not yellow light.
Nov 9, 2015 | 09:07 AM
BlueFinn
Nov 9, 2015 | 10:16 AM
Now that it's getting darker earlier I think I will darken up my licence plate bulb lenses, I put leds in there too, but they're too bright
Nov 9, 2015 | 11:35 AM
My son took my tag off & sprayed it with some solution he got. It dried clear but at night, it's very rreflective and from even a short distance the numbers look washed out and unreadable.
Nov 12, 2015 | 10:09 AM
License plate light
Went to do license lights saw no screws. went to forum manual listing and it shows slide light lens to the right and then drop down Had to get my plastic tools to get it to slide. After that no problem done.
Just a matter of what your tastes are as I like the white led lights.
Nov 12, 2015 | 10:14 AM
I have been buying the 10 and 20 packs of T10 LED's off amazon for years, in other cars, it took 6-8 of them for the interior, plate, etc. The only downside is these burn out after a year or so but just pop another in and you're good for another year. Also remember these are polarity sensitive and sometimes the prongs need to be bent a bit better for contact.
