Convertible top creeking
Old Nov 11, 2015 | 12:49 PM
don7790's Avatar
don7790
Default Convertible top creeking
I have a 16 Vert and have a annoying creaking coming from the third bow in the top. Anybody know how to access the bows. Cant seem to get to them without dropping the inner liner. Not sure the undertaking needed to do that. I am sure if I could get to the area where the noise is I can repair the problem. Anybody have dropped that inner liner? Thanks for the help.
Old Nov 11, 2015 | 12:56 PM
scottiekay's Avatar
scottiekay
Originally Posted by don7790
I have a 16 Vert and have a annoying creeking coming from the third bow in the top. Anybody know how to access the bows. Cant seem to get to them without dropping the inner liner. Not sure the undertaking needed to do that. I am sure if I could get to the area where the noise is I can repair the problem. Anybody have dropped that inner liner? Thanks for the help.
I have a 16 convertible also and I have the same issue. Not sure where you live but in the hot weather it creeks and in the cold weather it doesn't. Its very odd but drives me nuts. I posted this very same thread a while back and nobody had responded. I'm in Massachusetts so it's 50-60 degrees out and it does not make a noise right now.
Old Nov 11, 2015 | 02:54 PM
don7790's Avatar
don7790
Yea I live in Ma also. I am sure if I could get to the creaking I could fix it. I will keep you updated if I learn anything.
Old Nov 11, 2015 | 04:41 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
My 2014 snaps and pops as it is raised and lowered, but no creaking that I have heard...
Old Nov 11, 2015 | 04:45 PM
meyerweb's Avatar
meyerweb
No noises like that on my 2015. But I think you're right that you'll need to separate the top to access the internals. Sounds like a warranty repair to me. That way if the dealer screws up the top they'll have to take care of it.
Old Nov 11, 2015 | 09:16 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
One of the advantages of being OLD....I don't hear NOTHING....I have the most quiet 2016 Corvette Stingray Convertible ever made....
Old Nov 11, 2015 | 09:42 PM
John Ulrich's Avatar
John Ulrich
Mine has a "creak" on the passenger side in the middle by the hinge. I took a napkin that was handy and stuffed it under the wire loom and that cured it.
Old Nov 11, 2015 | 10:30 PM
MikeyTX's Avatar
MikeyTX
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
The top go up ? How novel ...............
Old Nov 12, 2015 | 08:15 AM
Parker Corvette's Avatar
Parker Corvette
That's a warranty repair. Good grief another quality issue. At the price of a C7 convertible this should not be happening. Coupe or convertible it seems that the top creaks. My coupe rove me nuts before I traded it off.
Old Mar 10, 2016 | 08:47 PM
Bonanza26's Avatar
Bonanza26
Hi John where exactly did you put the napkin
Old Mar 10, 2016 | 08:55 PM
L8ter's Avatar
L8ter
I am just not going to go there, but it might be just one of the reasons convertibles are not more popular.
Old Mar 11, 2016 | 12:39 AM
UncleFodder's Avatar
UncleFodder
Meh - my 2014 with 3500 miles is absolutely quiet and tight.
Old Mar 11, 2016 | 12:48 AM
joemessman's Avatar
joemessman
I wish I had a wife like that.
Old Mar 11, 2016 | 01:12 AM
owc6's Avatar
owc6
You want a wife with 3,500 miles on her?
You do know that's way over the milage considered "broken in"?
Old Mar 11, 2016 | 06:46 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
I've had 5 of them including the '15. I'm simply at a point in time where I prefer a coupe with the see through roof panel.
Old Mar 11, 2016 | 09:45 AM
capecodvette's Avatar
capecodvette
no problem, noises with my 2016 Z51 convertible
Old Mar 11, 2016 | 10:23 AM
joemessman's Avatar
joemessman
No. A wife that is quiet and tight.
To Convertible top creeking
Old Mar 11, 2016 | 05:54 PM
Larry/car's Avatar
Larry/car
My top has no unusual noises. There is some noise when cycling top up or down as various components position during the process. Convertibles are just so much fun, I will never get another coupe.
Old Mar 16, 2017 | 08:20 PM
Vettlldo's Avatar
Vettlldo
My 2017 GS vert w/2200 miles just started creaking once it gets hot. 2 things I will look for since my 2012 GS vert had the same issue/resolution: 1) Be sure the waterfall is not rubbing on the tonneau cover. If it is, push down on the waterfall to expand that gap between both items. 2) There is a hard rubber/adjustable stop just under the middle of the deck lid and tonneau cover. Unsnap the top protector in the trunk and try moving the support bar where the stop is screwed into. If you can duplicate that annoying creak, put a few drops of bicycle chain lube (teflon) on the rubber stop and it should stop the creaking.
Old Mar 17, 2017 | 02:47 PM
Bonanza26's Avatar
Bonanza26
Default Convertible Top Noise
I took mine to a dealer and the fix was very easy...there are apparently screws along the underside of the support bar...one was not tightened properly...fix took 20 minutes and no problems since
